Help... Sidebar going crazy
rumk
I have been using Vista for the past 3 months without a problem. Recently my sidebar has gone corrupt. All it shows is the orange date gadget. I have (12*5) 60 of those calendars appearing on my sidebar. Each time I try to close one, the system freezes for a few seconds and then the gadget comes back on.
I tried restarted sidebar, restarting my computer etc but it didnt help. I can add new gadgets and remove them, but I can't remove those 60 instances of the orange calendar.
The attachment shows what it looks like.
No help yet? Have I posted this in the wrong forum category or has no one had this problem yet?
Hi rumk,
Welcome to the forum.
Sometimes it will take a little longer to get an answer, I have never had this problem so here goes;
Do a scan for Virus's If you need use this;
FREE antivirus software with spyware protection: avast! Home Edition
Do a Scan for Spyware try using this;
Malwarebytes.org
After the scans have given your PC the OK
Go to, Start, Computer, C:\Program Files (x86)\Windows Sidebar\Gadgets
Try deleting all instances the offending gadget
Let me know how you get on
Pooch
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Enermax Chakra
    Easy Line Laser Mouse
    Standard
