Help with BSOD
Used to happen a lot, but then it was fixed. Im not exactly sure what i did to fix it. Yesterday as well as today it's been happening regularly every few hours. HELP PLEASE!
Thanks in advance
32bit Operating system
http://www.mediafire.com/?mzenynizn4r
^^ is the link, none of my browsers will let me upload directly as it says "Upload Failed after a few minutes"
    Hp Pavilion a1730n
    4600+ AMD Athlon 64 X2 Dual Core Processor
    2048MB
    Nvidia GeForce 6150 LE
Hello u5cevryday,
The RaR file seems to be damaged, can you upload another one, thanks.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Mini062910-03.zip
^^ i know the forums ask not to use third party uploaders, but whenever i try to upload directly it says "Upload failed"
if i try to upload from link it comes up as damaged.
Sorry for the inconvenience, hope you can still help me.
    Hp Pavilion a1730n
    2048MB
Got the dump files, looking at them now, not too many then. ;)
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
This is the result of your bugcheck, (the last four).
STOP 0x00000050: PAGE_FAULT_IN_NONPAGED_AREA
Usual causes: Defective hardware (particularly memory - but not just RAM), Faulty system service, Anti-virus, Device driver, NTFS corruption, Bios.
Probably caused by : Ntfs.sys
Open a command prompt as administrator and type sfc/scannow press enter and let it scan, if errors are found you will have to scan again until clean.
What AV do you use ?. For the moment, disable your AV. (don't forget to re-enable it when this is fixed).
If anything is over-clocked set it back to default for now.
Can you confirm that you have all the Windows updates and service packs installed.
I would check your HDD too, just to be on the safe side.
Hard Drive Diagnostics Tools and Utilities (Storage) - TACKtech Corp.
Download and run Memtest, scan overnight, at least six or seven passes.
The faulting driver could not be read by the debugger, so you may have to run the Driver Verifier.
How to identify a buggy device driver on Windows Vista | Vista Rewired
I will check your driver dates when i get a moment and get back to you with any that may need updating.
Hope this helps, good luck,and if you need any help with any of the above, just ask, if i am not on-line there will be others who can help you.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
i'm not really sure what you mean by AV? sorry im new to this kind of thing. Yes i have all the updates and service packs installed which is what i think fixed mY BSOD the last time. i'll do what you asked and get back to you if i continue to experience problems. Thank you for your help :)
- and nothing is overclocked
- how do i find out my hard drive's manufacturer? i googled came up with nothing.
    Hp Pavilion a1730n
    2048MB
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
All these drivers are over two years old, some are Windows system drivers and may not be up datable, but if there are updates for them, then i would advise you to get them.
I have included as much information on them as i can get.
Code:
xaudio.sys  Conexant audio system driver file
peauth.sys Microsoft Windows Protected environment authentication and authorization  export driver that should be located in the C:\Windows\System32\drivers  directory.
[B]Mdmxsdk.sys[/B] with description Diagnostic Interface  DRIVER is a driver file from company Conexant belonging to product  Diagnostic Interface.
[B]secdrv.sys [/B]A SafeDisc drivers that provides  CD/DVD copy protection and digital rights management for [U]Windows[/U]  applications and games.
spldr.sys   loader for security processor
[B]Nvstor.sys[/B] with description NVIDIA® nForce(TM) Sata  Performance Driver is a driver file from company NVIDIA Corporation  belonging to product NVIDIA nForce(TM) SATA Driver.
Hope this helps, good luck and post your results.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Funny you should ask about the antivirus. I just wanted to see if it were infact my anti virus and attempted to unisntall it twice, however my windows crashed into the BSOD both times. Does this mean it's the antivirus? I'm using BitDefender 2009 Total Security.
Was supposed to be good =(
Thanks for the software, i'm on it right now
    Hp Pavilion a1730n
    2048MB
thanks, i'll update those drivers right now
    Hp Pavilion a1730n
    2048MB
sorry im not exactly sure how to update the drivers taht you specified.
im only aware of updating through device manager? is that the only way? or is there a specific way to update the .sys?
    Hp Pavilion a1730n
    2048MB
i updated everything i could through device manager. i was wondering if tehre were other ways to update the drivers you listed other than using device manager, becaase im pretty sure i didnt update as many as you listed.
    Hp Pavilion a1730n
    2048MB
i also disabled Bitdefender and i haven't experienced the deadly screen so far. HOwever whenever i try to unisntall it through contorl panel my computer crashes.
any ideas for a workaround to uninstall the antivirus?
    Hp Pavilion a1730n
    2048MB
Have you checked the website for a complete removal .exe program which will uninstall it
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
This will un-install Bitdefender for you.
How to uninstall BitDefender
When this is un-installed, download Microsoft Security Essentials, its free and very good. Please don't be put off by the fact its MS.
Some of those drivers i mentioned probably won't be up-datable as they are MS files installed with Windows.
If you have trouble finding them, try Google, if they are out there Google will find them.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Apart from the drivers i mentioned, update your Sound, Video and Chipset drivers.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
thanks i managed to uninstall bitdefender and isntall security esentials.. it lacks a firewall though (any suggestions?) Also im still confused as to if all the drivers are to be updated through device manager or if there are other methods to update?
    Hp Pavilion a1730n
    2048MB
I would use windows Firewall it does what it needs too
    AMD HD Radeon 6870
    Novatech Night
So far so good after installing everything. I still need ti run the Memtest scan, and im not sure what to do with the HDD diagnostic software :S.
    Hp Pavilion a1730n
    2048MB
i installed all the driver updates
and ran "DriverScanner" just to be sure everything was done. but it says my realtek high definition audio device is out of date. when i try to download it from their website it doesnt download. any ideas where i can get this from?
    Hp Pavilion a1730n
    2048MB
