flycaster
		My 3:4 flat panel LCD monitor's native resolution is 1280X1024.  However, when I set Vista to that resolution, the text and everything else is very, very small.  The next best resoultion (i.e., without elongation distortion) is 1152X864.  I thought that in order to maximize one's screen picture, one should run at native resolution, but this doesn't seem to be the case.  I also do a little photo processing and want the best screen resolution for that.  It seems that if I want undistorted screen images and reasonable sized text, I have to compromise with 1152X864; or am I missing something?  Thanks for you help.
