Solved Help With Reinstalation. Boot - From Desktop.
Elite Knight
ANIME MAD!!!
I'm not sure where this goes but i was wondering what would give my system the best performance after a reinstall.
Boot
Or From Desktop
I have Windows Vista Ultimate 32&64bit. Going to install 64Bit.
System Rig
1TB RAID 0
Nvidia Geforce 8600GT 512MB Shared 1279MB
Intel Quad Core Q6600 2.4Ghz
4GB DDr2 Ram
Whats the Best Reinstallation Method
    NEC PowerMate V7330
    Intel Quad Core Q9650 3.0ghz
    Gigabyte
    4GB DDr2 800Mhz
    Nvidia Geforce GTX260 1GB Edition
    Sound Blaster 7.1 High Def Audio
    AOC 193Fw
    1440X900
    5X 1GB Seagate 32MB Cache 7200.12rpm
    650Wat
    V9 Case
    300mm Fan
    G5 Logitech
    NEC Keyboard
    24000/19000 ADSL +2
    I like this PC.
Thank you for the replay i will get on it tomorrow my network download speed is capped at 10KB because we use a limet and i need the Slipstream thingy to do and i dont have any blank dvd's or cd'rs so i have to wait.
    NEC PowerMate V7330
    Gigabyte
    4GB DDr2 800Mhz
    AOC 193Fw
    1440X900
    650Wat
    V9 Case
    300mm Fan
    G5 Logitech
    NEC Keyboard
    24000/19000 ADSL +2
    I like this PC.
You're welcome Elite Knight. If you have any questions while doing this, please feel free to ask.
Ok thanks. And can u use multipul cd'rs to install vista 64bit.
    NEC PowerMate V7330
    Gigabyte
    4GB DDr2 800Mhz
    AOC 193Fw
    1440X900
    650Wat
    V9 Case
    300mm Fan
    G5 Logitech
    NEC Keyboard
    24000/19000 ADSL +2
    I like this PC.
Also does it madder if i used XP format tool when i tryed XP on here will that effect the Hard drive in anyway. Also if i use vista format tool as well. Performance. I just did a quick format will that do anything On XP.
One more thing if a system comes with a OS and you downgrade and it seems slower is that normal because I was thinking this computer is made for vista.
    NEC PowerMate V7330
    Gigabyte
    4GB DDr2 800Mhz
    AOC 193Fw
    1440X900
    650Wat
    V9 Case
    300mm Fan
    G5 Logitech
    NEC Keyboard
    24000/19000 ADSL +2
    I like this PC.
Elite,
Normally Vista comes on only one DVD, but I suppose if it came packaged that way it would work fine.
It would not matter if you formated the drive or partition with XP first. Since Vista has the option to format during installation, it would be best to use the Vista format option instead.
It depends on if you have drivers for all of your devices for the OS that you downgraded to. If not, then that could impact performance. Vista was designed to take advantage of and use more of the resources it was given. This tutorial can help speed Vista up for you though.
Thanks again it's ganna take a while a 1TB hard drive.
    NEC PowerMate V7330
    Gigabyte
    4GB DDr2 800Mhz
    AOC 193Fw
    1440X900
    650Wat
    V9 Case
    300mm Fan
    G5 Logitech
    NEC Keyboard
    24000/19000 ADSL +2
    I like this PC.
I TB, oh yeah. It may take a little bit to format. ;)
