Help with soulseek
PGERARDJ
HI:
I am using a new Alienware M17 w/Vista Ultimate X64; installing soulseek, you are asked for name, password and to verify password, but each time any version loads that I install, the verify box disappears right away so I can't install soulseek - any help would get my eternal gratitude.
HI:
Hello PGERARDJ, Welcome to the Forum.
Try right clicking on the .exe before you install and select Run as Administrator. Should this not work, Right click on the .exe again and select Properties, Select the Compatibility tab and put a tick in the boxes, Run this in compatibility mode for Windows XP (Service Pack 2) and Run this program as an administrator
Click on Apply and OK then try again to install the program.
I hope this helps
Pooch
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Enermax Chakra
    Easy Line Laser Mouse
    Standard
