Help?..
Vista Dan
Banned
Ok, I have Vista ultimate right? I go to Microsoft site cause I want the Korean IME since I am korean. But, the language pack says that its not compatible. Yes I have tried SP2 compatibility mode. No pleasure.
Could someone provide a link for a Vista Korean IME please? Much thanks,
Dan
    Pentium 4 OC'd to 3.0GHZ and a Pentium Dual Core E2180 @2GHZ
    Gigabyte GA-***** and a ASUS model
    768MB DDR1 / 2GB DDR2
    RADEON 9800 PRO / NVIDIA Geforce FX5200
    Intel built-in AC'97 Audio / Realtek High Def Audio
    Samsung SyncMaster 913V/213BW / Acer X193
    12**x10** / 10**x7** / 16**x10**
    1: 320GB SATA 2: 20GB SATA 3: 40 GB SATA 4: 150 GB SATA
    Not sure
    ASUS ASPIRE / HP Pavilion 754n / Custom
    Not sure
    Razor DeathAdder / Logitech Wireless / Acer Wheel mouse
    NeXXTech Office KeyBoard / Acer Keyboard / UNITECH
    100MBits per second
    Happy right now ^^
I never needed to download anything from a website to get korean language support for windows xp. You can just enable it by using Control Panel->Regional and Language Options. Then click on the languages tab and click install files for east asian languages, then you can also setup your keyboard language switcher button there also. XP will ask for your XP disk then will make you reboot. I am certain that vista works in a similar manner. I think you need to look at your update center, you may install available languages for Vista through the update center. Make sure that you look at the optional packages in update center, I saw the language support for vista there.
    Intel Quad Core 2.66Ghz
    Dell
    3GB
    NVIDIA 8800GT
    2qty 500GB SATA 7200RPM RAID Performance Stripe
Unless you have Vista, I dont want comments, Sorry.
    Not sure
    Not sure
    100MBits per second
    Happy right now ^^
Umm, I have Vista. I just told you where it was.
    Dell
    3GB
    NVIDIA 8800GT
Listen to the man.....
Go to Control Panel the go to Clock, Language and Region and the Regional and Language options....
It is there..... I just tried it
    Q6600
    MSI P36 NEO2
    4GB 5-5-5-12
    8800GTS 512Mb Overclocked
    5.1 surround sound
    500Gb Samsung SATAII XP 500GB Samsung SATAII
    1000W CoolerMaster power supply
    CoolerMaster Cosmos 1000 case
    120mm ThermalTake Big Typhoon CPU cooler, 3 x 120mm exhaust
    Wireless Keyboard and mouse 3000
    1TB WD My Book Office edition external drive x 2, Dual layer LG DVD-Rom burner, 15 in 1 card reader Triple boot: XP, Vista Ultimate 64 and Windows 7 Ultimate 64
Well maybe its because mine isn't .... a normal Vista.
    Not sure
    Not sure
    100MBits per second
    Happy right now ^^
We only help people with legitimate copies of Vista ... :sarc:
Later :( Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
Hello Dan,
Could you explain what you mean by "mine isn't .... a normal Vista". It may have a lot to do with the problem you are having.
