help!
Error on every startup loading dxrdiqif.dll,what does it mean? in msconfig the startup item is rxknvlcsu!
What else is in msconfig? can you upload a screenshot?
Do you have an anti viruus app? current and running?
What exactly does the error say? when in start up does it happen?
ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
hi, i attached it here, i hope u can see it, there are 2 fishy ones from unknown manufacturers, u can see them here.
i use avg free and its active and running, i just updated and scanned, it only found some tracking cookies which were healed.
it says error loading dxrdiqif.dll and it comes when my desktop appears, everything else works just fine, my computer has not had any other symptoms at all. it started happening like 10 days ago.
except once, i had a blue screen like 3 days ago and had to restart, but then after it worked fine.
You seem to have done a good job disabling things. I assume you want to remove it.
That file is in the 32 bit programs folder. do you have your search to index the whole drive or just sertain folders?
Ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
