Solved HELP!
my computer used to see(recognize) my memory (SD)cards before,then it just stopped one faithful day.actually i have this software that on activation,it tells me the drivers my computer needs.and ever since i downloaded and installed this drivers it has stopped working(my SD card reader).
when i check device manager the SD memory card shows this yellow marking on it and when i double-click on it,it tells me ,THIS DEVICE CANNOT START(CODE10).i have tried uninstalling,i have even tried upgrading,but none of them worked. i use a Dell laptop,VOSTRO1510.PLEASE HELP ME.:cry:
    dell/vostro 1510
    176gb
Re: HELP!!!!!!!!!!!!!!!
1. Get rid of this driver program - use REVO uninstaller (advanced option).
2. Uninstall the driver in device manager and reboot.
    Dell
    Q6600
    HP w2207h
plEase,were do i get this REVO uninstaller from?anyway i have tried uninstalling from the options given to me after double clicking,and its still the same thing.
Someone suggested to me that i should "FORMAT" the system partially (THAT IS FORMATTING,BUT ACTUALLY NOT FORMATTING.MORE LIKE A RECOVERY OF THE DRIVERS)since .all my document and settings will still be intact,but all the drivers will be set back to their initial state as when i just bought it.
HOW ABOUT THAT?:cry:
    dell/vostro 1510
    176gb
Go here to download REVO...
Use it to remove the software program that is telling you what drivers you need.
Once that software is removed, use the device manager to uninstall the driver for your card reader. When you reboot the computer, Vista will find the correct driver and load it automatically...
Do NOT reformat without trying what whs has suggested...
Regards,
Michael
    ME / 0026 (yeah, at LEAST that many systems)
    Intel Q9550 Quad Core
    Gigabyte GA-E7AUM-DS2H
    OCZ DDR2 PC2-6400 SLI-Ready Edition 4GB Dual Channel
    Gigabyte GV-N210OC-512I NVIDIA GeForce 210 GPU
    Realtek / Nvidia (built in) Dolby Home Theatre
    Dell 22" Widescreen LCD / Vizio 47" 1080p LCD HDTV
    Native / 1080P
    Not Enough (SAMSUNG F1 RAID CLASS 250GB SERIAL ATA/300 7200RPM 16MB BUFFER HARD DRIVE - HD252HJ) for now
    ANTEC EA380
    ANTEC NSK2480 Desktop case (HTPC)
    3 ANTEC 120 mm TriCool™ 3-speed fans / INTEL stock CPU Fan
    Microsoft Wireless Mouse 5000 (cool blue laser!)
    Microsoft Wireless Comfort Keyboard 5000
    VERIZON FIOS 25/25Mbps (Required for HDTV - Darn!)
    HTPC / Main system...build 4/28/2009 - Burning in...So far, wicked fast, especially internet...Hulu on the Vizio while I'm working on the dell...TV never looked so good!
i will do just what you asked me to,but i'm presently out of power,which means i'll do it first thing once i get power.i have already downloaded THE software anyway.i will keep you posted.THANKS JIDE.
    dell/vostro 1510
    176gb
ogunleyeolajide,
No problems...everyone here is always happy to help. These programs that tell you they will make sure all of your drivers are up to date are tempting, but they usually cause more harm than good. I personally have my systems set up to back up files weekly, do a system restore point weekly and use MSE to do a full scan weekly. I keep CCleaner handy to clean up every so often too ;).
All My Best,
Michael
    Native / 1080P
    ANTEC EA380
ogunleyeolajide,
All My Best,
Michael
ogunleyeolajide -
Michael's use of system restore points and CCleaner is very wise. For more information on how to maintain your computer's system performance click the link below.
http://www.vistax64.com/tutorials/81176-speed-up-performance-vista.html?filter
    HP Pavilion Elite
    Some Amount of Motherness
    6.O GB RAM
    Some Amount of Soundness
    1440x900 & 1440x900
    WD Caviar Blue 500GB
    Some Amount of Voltageness
    Hp Pavilion Elite Case
    Some Amount of Coolingness
    HP: M/N:M-SBQ133
    HP: Model Number: KB0911
    Comcast: 20 MB/S
i did exactly what you ask of me,uninstall the driver program software then reboot the system,some how it didn't work.but out of curiosity i started playing around with some stuff,like getting a DELL 1500 SOFTWARE from a friend and running it so as to fix any problem,And surprisingly it worked.So now it works perfectly fine,i even used it to check other minor issues and they all work fine now.THANK YOU VERY MUCH FOR YOUR CONCERN AND CARE,I REALLY APPRECIATE IT.JIDE
    dell/vostro 1510
    176gb
ogunleyeolajide,
I am very happy to hear that you were able to get your system working!
All MY Best,
Michael
    Native / 1080P
    ANTEC EA380
