Solved hi i have a problem
darkelf69612
hi guy new to the forum so looking for some help please!!
my computer will not start in normal, i can start it in safe mode but when i select start vista it just restarts itsself and i have ran system repair about 10 times and still no luck does anyone have any advice on what i can do thank you or if you need anymore info it is windows vista aswell guys thanks
ps: and windows update wont open i click it and nothing happens aswell thanks
pss:just to rub it in more i dont have any restore points either.
It seems like its either an update or driver issue. Someone else on here will post how to clean boot and then selective restarts to narrow the issue down.
Basically, in my opinion, something got borked, so when your booting into normal start its hanging, but in safe mode, it doesnt load that driver or software.
I'm not great in this part of vista, so i'll let someone else continue.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
I have just installed a new windows but now cannot connect to the Internet will I have to manually plug the Ethernet cable in or can I get the driver from my windows l.old file to replace the new one an which one and were is it please thanks for your reply mate!!!
Welcome
Patonb is correct. If you boot ok in safe mode,its a software issue. Now the difficut part, what software. Maybe a clean boot will help us diagnose.
Troubleshoot Application Conflicts by Performing a Clean Startup - Windows 7 Forums
EDIT: You posted at the same time as me and now the problem is different. With another computer, you can download any necessary drivers to a finger drive and then transfer to your problem computer.
Hi rich yeh just done a install and it now works!!! Kept my old windows file though but like I said in my last post I cannot connect to networks now maybe because I don't have the driver can I get that driver from my old windows file??
Ps:I only have this one laptop and a iPhone haha so if I just connect it through the Ethernet it should work shouldn't it???
Unfortunately, you may not still get on the network, but if you used a recovery disk to redo windows, most likely the reason you csan't get on the net is due to you no longer having the passwords saved.
Thats easy to fix by clicking on the computer shaped symbol by the time in the lower right corner.
You can find If you need drivers by going to the device manager and looking for red X or yellow ?
I would still do a clean install, it is always the best. If you still do not have internet, follow Patonb, but do a clean install.
You have already donated with your thanks and appreciation. Good luck.
I always say if you pass on your knowledge gained here, then you've repaid us/The forum back.
So go forth with your new knowledge and educate others.
