hi just a bsic help thanks with monitor
ohsocute69
ok all my pc has been redone, no more problems only for this
i have no widescreen , the picture fills up the widescreen no problem but when i open an application like this i have here shown its reall skiny and writing is so small
its annoying i cant work it out id rather go back to my square screen at the moment..also my writting (fonts is diffrent as well) its not the same as what i had ...but help with the first question woulkd be great thanks
click on the little box next to the X then,
To get it to always open full screen hold the shift key down and close the page with the X
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
yes i have done that but i never have played this in full screen, yuk, lol
what i mean is normaly before hand when i open this application on the old monitor it was a little larger in size , and also the writting now has also gone smaller i vae adjusted fonts but its still smaller even when i type on notepad writting is thiner when it use to be thicker when now its real thin , i hate it , is thius what wide screen does ? makes writting thiner and hard to see..?? this is that application on full screen it horrible even worse i use to have it samll see it clear and no problem
Right click on the desktop go to personalize, on the right side (in classic view)
Adjust font size (120DPI)
To make the open page just a bit bigger go to the edge of the open page and your pointer will change to a double headed arrow click and drag the page to the size you want.
    LENOVO 64734VM
    15 inch
i have some nivada graphics on my pc is it necessary i think this is why it funny
that is set on that 120, but the writting is real thin its horible i have been trying to get it back to like when u buy ur pc from shop
go to start control panel on the left side is classic view.
You may have to set your screen resolution yet.
the adjust font size is on the left not the right as I said earlier.
    LENOVO 64734VM
    15 inch
control panel,(or right click desktop)personalization,display settings,
EDIT: Did you change the font?
Do you use Aero or classic mode?
    LENOVO 64734VM
    15 inch
Then set the Resolution to the Highest Possible
Hope This Helps,
Josh
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
Hope This Helps,
Josh
Yeah it does.
need to know if it's run in classic mode or Aero now for the "skinny" font
:D
    LENOVO 64734VM
    15 inch
    LENOVO 64734VM
    15 inch
Hello again.
Right click an empty spot on the desktop and select Personalize, then click Display Settings, have a play with these settings to see if you find one that works for you; be sure to post back with an update.
click an image to enlarge
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
i have done nearly everyhting i can could it be the softwaRE or the widescreen making the writting now thineer and smaller , as it use to be like just from factory thick easy to see writting , does widescreen or thsis software i have on here nividia change all this ??
Did you try my suggestion above?
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
In notepad go to format, font, change the size here.
    LENOVO 64734VM
    15 inch
