I'm experiencing a problem with newsgroups in WinMail. I set the current view to Hide read messages, but it on exiting all messages are hidden. Is there something else I should have done or is it a problem that still needs to be fixed?
Please follow this :I'm experiencing a problem with newsgroups in WinMail. I set the current view to Hide read messages, but it on exiting all messages are hidden. Is there something else I should have done or is it a problem that still needs to be fixed?
(Menu Bar) click VIEW > Current View, click Hide Read or Ignored Messages > Customize Current View >
1.) under Selest the conditions ......
check " Where the message has been read "
2.) under View description ......
change to " where the message has BEEN READ " OR where the message is IGNORED
and " HIDE the message "
> OK > OK
t-4-2
OK, make a slight change.......Please follow this :I'm experiencing a problem with newsgroups in WinMail. I set the current view to Hide read messages, but it on exiting all messages are hidden. Is there something else I should have done or is it a problem that still needs to be fixed?
> OK > OK
t-4-2
Thanks for your help.
It does all these things, but on LEAVING the newsgroup, those messages that I have not read and want to come back to later are hidden. Is there not a way that I can (on returning to the newsgroup) see those?
> OK > OK
t-4-2
View > Current View, click Copy of Hide Read Messages ( note : NO Ignored messages ) > Customize current view. See if it has changed to just " where the message has Been Read " and " Hide the message ". No more IGNORED. If yes, OK yourself out.
Try reading one newsgroup message,exit then return. See if the rest un-read messages are there. It works on my computer with the same settings.
t-4-2
I have tried the following several times. I read one, shut down WM, came back and the unread messages were there.OK, make a slight change.......Thanks for your help.
t-4-2
Did that and all messages disappear on exit. try and see if you have the same problem.
t-4-2
VIEWS > Current View ( don't bother to click any options there ) > Customize Current View . Under (1) change to " Where the message has been read ".
Under (2) change to Hide the message. > OK
Now try it. t-4-2
My last trump card.I have tried the following several times. I read one, shut down WM, came back and the unread messages were there.Did that and all messages disappear on exit. try and see if you have the same problem.
Now try it. t-4-2
Done that. On leaving a newsgroup all message disappear.
The only checked boxes are: delete all news messages 5 days after being downloaded and compact the database after 100 runs.My last trump card.I have tried the following several times. I read one, shut down WM, came back and the unread messages were there.
Now try it. t-4-2
Tools > Options > Advanced > Maintanance. Make sure " Purge newsgroup messages in the background " is NOT checked.
If it is still " no go ", go back to the default setting.
I am stumped. It works on my machine.
t-4-2
The only checked boxes are: delete all news messages 5 days after being downloaded and compact the database after 100 runs.My last trump card.Done that. On leaving a newsgroup all message disappear.
t-4-2
The messages have not been deleted because when I go back and they are not showing and I go to view - show all messages they return, the unread ones are marked as read (not in bold).
Thanks for your help anyway. I will continue to experiment and if I find a solution I'll post it here. Something I noticed is that in current view that a "copy of hide messages" appears for each time you change something. What is that for?
