You should upgrade or use an
alternative browser .
Solved Home Premium Restart
My restart time went from 1min 3sec to 1min 28sec and the only thing I did in between times was run chkdsk.exe which came up with a clean report.I did 3 consecutive restarts to confirm this extended time.I also ran autorun.exe and all items were the same.What else could I check into?
Acer 380
AMD Athon 64 x 2 4000+
2GB DDR2
Realtek HD Audio
TTX 17"
800 x 600
SCSI NTFS 320GB
DSL
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
TerraMaster F8 SSD Plus NAS
Galaxy S23 Plus phone
Operating System
Thx. for the quick reply Shawn and I had previously applied the useful information you referenced to.I believe my present problem stems from me manually running chkdsk.exe and it made a change(registry) to the "bootexecute value".The added start time seems about equivalent to when you do an improper shutdown and next startup it does a quick disk check for errors.Could you guide me as to what the default value should be.
Acer 380
2GB DDR2
Realtek HD Audio
TTX 17"
800 x 600
SCSI NTFS 320GB
DSL
Shawn....I just wanted to let you know I was able to correct my problem by changing the value for "bootexecute" back to it's default value of " autocheck autochk *"
Acer 380
2GB DDR2
Realtek HD Audio
TTX 17"
800 x 600
SCSI NTFS 320GB
DSL
Krd67,
I'm happy to hear that you got it sorted out. Thank you for posting back.
Operating System
Operating System
HappyGuru Lovin2Help
where was this located?
gateway/m6881
3GB
500GB WD
logitech
fios 35MB not!!!!
