Solved How can I hide "Help and Support" on the Classic Start Menu on Home Premium?
lipskid68
I am trying to hide "Help and Support" on the Start Menu. I use the "Classic" menu and I am running Vista Home Premium. The “gpedit.msc” feature is not included with Vista Home Premium. It is only available when using Vista Ultimate. I suspect it will require registry tweak but I don’t know how to do it.
    Toshiba Satellite A305-S6829
    Intel Centrino
    3 GB
    Mobil Intel 965 Express Chipset Family 358MB
    298 GB
    Cable
re: How can I hide "Help and Support" on the Classic Start Menu on Home Premium?
have you tried removing it using the start menu properties\customize
you can add or remove programs there
Thank you "Brink". That was perfect, it worked like a charm, awesome. Thanks again, H.
    Intel Centrino
    3 GB
    298 GB
    Cable
Your welcome LipSkid68.
