Solved How to delete inbox contents
gardencharlie
I use my Gateway laptop with Vista Home Premium infrequently, mostly when traveling, and when I start it up it downloads to Windows Mail ALL the incoming emails since I last started it up. I now have over 4000 emails in the inbox and want delete the inbox contents in one fell swoop. How to do?
    Gateway Model M-6307
    Intel Pentium CPU T2330
cursor on first mail then hit
Shift and down arrow
Then delete
May take 3 or 4 swoops
May not be able to delete all at once.
First let the software load & then select the first mail message.
Press CTRL A (this will select all messages)
Press DEL (delete all messages)
click YES
Wait for it to finish & then your done!
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    BluRay & DVD Weiters
    40 Meg
Thanks, Lottiemansion...worked perfectly, also on the junk mail file. All went to deleted file, which I then emptied. Gardencharlie
