Solved How to Remove Old Account
boweasel
A friend of mine bought a used Vista desktop a several months ago and I helped her get it set up. Everything was fine until a few days ago when she began getting the following message on the Welcome screen:
The user name or password is incorrect
Once she gets that message she can click okay or cancel (I forget which exactly), and then she gets a sign-on screen for what I assume is the original user with a password box. She then has to click 'Switch User' to get her name and password box to pop up.
I assumed we could just go to the control panel for user accounts (my friend is an administrator) to delete that other account, but it doesn't display. When I click 'manage another account' the only choices are Guest and my friend.
What is this other account and how can we get rid of it?
MilesAhead
Eclectician
Accounts in the Administrator Group in Vista and later are very close to the old Operators Group used in NT Server. You can install programs, register activex controls etc.. But you can't do everything. To access the whole enchilada you have to activate the built in Administrator Account. Here is how to do so:
http://www.vistax64.com/tutorials/67567-administrator-account.html
Once you create it, it should ask you for a new password. Then change user to the Administrator and you can delete the old account from there.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
boweasel
Following your instructions did nothing to alter the process, other than adding ANOTHER (Administrator) user to the sign on screen. On startup I still get the same message as before:
  • The Vista Globe displays on the black screen
  • The blue/green screen displays that says 'Windows Vista Home Premium' at the bottom
  • Right above the word Vista is a white X inside a red circle
  • To the right of the circle it says 'The user name or password is incorrect'. Underneath that is a selection box that says OK
When I click on OK, I get a user name
  • [email protected] with a white box for a password.
  • underneath that password box is another selector box labeled Switch User
  • When I click Switch User I get the same blue/green screen with 3 user names - [email protected], Administrator and Ruth (my friend's name)
  • Clicking on Ruth gives me the logon screen with only her name and a spot to enter her password
Entering her password gives me the Welcome screen followed by her desktop.
Logging on as the Administrator and going to User Accounts and clicking on manage another account fails to show the cfxxx731 account, so it obviously cannot be removed that way. I would post screenshots if I knew how to grab them without being logged on.
MilesAhead
Eclectician
In an elevated command prompt please enter this command
net user administrator
and post a screen shot of the results
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
Vistaar
Hello boweasel and MilesAhead, googling "wmconnect" suggests that the PC's original owner tried to make WalMart their ISP (in affiliation with Netscape/AOL). Unfortunately the old WalMart software was incompatible with Vista and probably didn't install properly, and I didn't see a good link on uninstalling it. In C:\Program Files, is there a folder called wmconnect or Netscape Internet Service?
    Vista Home Premium x86 SP2
    HP Pavilion Elite m9150f
    Intel Q6600
    3 GB
    NVIDIA GeForce 8500 GT
boweasel
Thanks for chiming in Vistaar. but no there are no folder in Program Files for anything Netscape or Wmconnect related. In fact a C:\ search turned up nothing for netscape and a lone registry entry for wmconnect.
I still can't figure out how she got a username (to show up on the login screen) that looks like an email address - it's got the @ as part of the name, and AFAIK you can't create a user name that contains that special character. And the user name never shows up even when logging on as Administrator.
This seems like way too trivial an issue to warrant a reinstall.
MilesAhead
Eclectician
Here you go...
Can you log into user Administrator or not? What I am thinking is perhaps the first owner of the machine enabled the built in Admin account and assigned it a password, but didn't think to tell you what it was. Then he may have disabled it. But once created with a password if you enable it you would be stuck needing that password to log in.
If that is what happened it leaves the matter difficult to deal with here because there are forum rules against coaching how to bypass passwords etc..
If you cannot log in to Administrator and that is the source of the invalid password error then you need to search how to restore your ability to set the machine up with yourself as the Administrator. The knowledge is out there. It is just that we are proscribed from providing links or explicit reference to it.
E
Edit: I changed the color of the text above to make it hard to read since there is no strike-through available. Rereading your post I see I had the wrong take on what happened. See if the command line approach described here works any better for removing the account:
I can't delete users account - Microsoft Community
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
boweasel
No. Nothing from that link did anything. The user name does not seem to exist in any normal MS manner. I actually looks like an email address, even containing the '@' symbol. The user does not display when I click on switch user. When I do that I can only see my friend's name and Administrator (of course Administrator never used to actually display, but it does now, after performing the process in post#2). The ONLY time this user displays is when we boot the computer.
I would love to provide a screenshot, but hitting prtsc before actually logging on fails to save an image to the clipboard.
boweasel
No, again. I'd already tried the control userpasswords2 befire posting, but I tried it again. My friend's name is Ruth. When the screen comes up I'm unable (either with the mouse or the up/down arrows) to move off of Administrator. And I don't see what the point would be - the cma****[email protected] isn't listed.
And other ideas? Or other forums? My friend is getting antsy - she misses her Facebook games.
Vistaar
Does the mysterious user have a folder in C:\Users? At this point I'm thinking probably not. I'm thinking Windows was once set to log on automatically to that account at startup. Perhaps the person who did this typed the password incorrectly...or perhaps "the user name or password is incorrect" because the old account was removed, or maybe just renamed Ruth?
I'm thinking what you want to do is Turn Off Automatic Log On, which should be as simple as checking the Users must enter a user name and password to use this computer box in your screenshot and clicking OK. It might be safer to first try setting Ruth's account to log on automatically. Here's a tutorial that Brink posted when Vista was young: http://www.vistax64.com/tutorials/66966-logon-automatically.html?ltr=L
    Intel Q6600
    3 GB
virtual6
Vista Pro
In his account screen, the deleted user is not displayed, so I wonder if checking users must enter name and password will be applied to the deleted user?
boweasel said things were okay, then this user name/password issue started...what changed?
Are there any registry entries for the cxxxx731 (or whatever) name (I'm thinking about Security Identifiers [SIDs] ).
boweasel
I don't know exactly what I did to effect the change. But when I now start the computer it now automatically bypasses any of the earlier nonsense and takes me directly into the desktop of..... the Administrator. No password needed. The only way to currently sign on as Ruth is to let the PC automatically boot to the Administrator desktop and hit Switch User. Then I get the screen with only two users - Administrator and Ruth. Clicking on Ruth then prompts me for her password, and then we're good.
So I guess I'm finally seeing an upward turn...
MilesAhead
Eclectician
What happens if you now disable Administrator from the command line?
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
MilesAhead
Eclectician
That is what the last link I posted was all about. Step by step.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
boweasel
ALMOST there. And thanks for your help, guys. Control userpasswords2 is not at all intuitive and I was perplexed by the sometime inability to move the selector OFF of Administrator. The only current small problem is that when I boot I am presented with 2 user names - Administrator and Ruth. Selecting Ruth works as it should, but AFAIK the Administrator is user only visible when booting in safe mode. It is now visible in normal mode. I'm sure following the link back in post #2 is the culprit.
Should I just disable that hidden Administrator account?
MilesAhead
Eclectician
Yes, that was all it took.
Great! Glad you got the inconsistency resolved.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
