HP MediaSmart Webcam problem
PucarB
Hello. I have a HP Pavilion dv5. HP MediaSmart Webcam came bundled with the computer. It worked fine. But now, it crashes before it can even start. But, it still works fine with Guest user. Please help !
    HP Pavilion dv5 Notebook PC
    Intel Core 2 Duo
    Quanta
    4GB DDR2
    Mobile Intel 4 Series Express Chipset Family 1821MB
    Intel High Definition Audio, IDT PC Audio
    Generic PnP Monitor
Hello Pucar, welcome to the forum.
I would like to recommend you to right click on this application to check the permissions , verify if the domain administrator belongs to the administrator group and make sure the domain administrator have enough permissions. Or you can launch the Computer Management, navigate to the Local Users and Groups, click Groups and click Administrators, make sure the domain administrator is the member of administrator groups.
Also check the driver status. is it up to date?
Thanks
    HP dv2519tu pavillion Laptop
    1.50 GHz
    Winstron
    2.5 gig RAM
    intel onboard
    Conexant HD Smart Audio HD2
    HP Brightview Display
    1280X800
    SATA - 160 + 500 GB
    HP
    HP Laptop
    Air
    HP
    HP Laptop
    4 MB/SEC-Download, 2 MB/SEC-Upload
If it is working on one account and not the other it could be a conflict.
Look in your event log to see what is causeing the error.
Click on start
Right click on computer and choose manage
click on continue
click on event viewer
look for errors that may match.
When you say it crashes what is the error that you are getting.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
Thanks
The domain administrator belongs to the administrator group. The application works totally fine with another user. So, I think that the driver is up to date.
    Intel Core 2 Duo
    Quanta
    4GB DDR2
    Generic PnP Monitor
Click on start
click on continue
This is what I could get from even log. I copied it all.
Log Name: Application
Source: Application Error
Date: 4/12/2011 8:15:02 PM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: PUCAR
Description:
Faulting application HPMediaSmartWebcam.exe, version 2.0.1.926, time stamp 0x48dcae6e, faulting module ntdll.dll, version 6.0.6002.18005, time stamp 0x49e03824, exception code 0x80000003, fault offset 0x00010004, process id 0x14a8, application start time 0x01cbf91e111cfc9c.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2011-04-12T14:30:02.000Z" />
<EventRecordID>54863</EventRecordID>
<Channel>Application</Channel>
<Computer>PUCAR</Computer>
<Security />
</System>
<EventData>
<Data>HPMediaSmartWebcam.exe</Data>
<Data>2.0.1.926</Data>
<Data>48dcae6e</Data>
<Data>ntdll.dll</Data>
<Data>6.0.6002.18005</Data>
<Data>49e03824</Data>
<Data>80000003</Data>
<Data>00010004</Data>
<Data>14a8</Data>
<Data>01cbf91e111cfc9c</Data>
</EventData>
</Event>
    Intel Core 2 Duo
    Quanta
    4GB DDR2
    Generic PnP Monitor
Hello Pucar,
I will recommend you to try to uninstall the HP Media Smart Webcam software completely from the computer and then reinstalling it again from the given link:
Software/Driver package
You can follow the given steps to uninstall the HP Media Smart Webcam software completely from the computer:
1. Click Start and then click Control Panel.
2. Under Programs, Click on Uninstall a Program.
3. Choose HP Media Smart Webcam software from the list and then click on Uninstall.
4. Follow On-Screen instructions.
5. Restart the machine.
Hope the information will help. Please revert back and let us know.
Thanks
    1.50 GHz
    Winstron
    2.5 gig RAM
    intel onboard
    1280X800
    SATA - 160 + 500 GB
    HP
    HP Laptop
    Air
    HP
    HP Laptop
hello there. i am using hp pavilion dv5, i just want to know why did my hp smart webcam not working? i reinstalled it but then it didn't work. can u please help me. thank you. :(
Monic08, can you start a new thred in the Windows 7 forums. The link is at the top of the page.
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
