I can only read english and a bit of italian but....
pacinitaly
HappyGuru Lovin2Help
does any one know what this says?
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
NO 1 ??????????? !!!!!!!!!!!!!!!!!!!!!
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
Hello Carmine,
Sorry I do not speak or read that language. If you are able to copy or type only the text, then you could use Google Translate.
Hope this helps some,
you ARE AWESOME, i'LL TRY
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
I can't copy any letters
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
thank you
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
Still the same problem. You need to extract the text from the image. :(
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
