I cant get simple screensavers to work! Help please!
KaeXIII
When i used to run XP, downloading a screensaver would usually just add it to my list in the screensaver menu. However, I have not found any way to get screensavers outside of the ones that came with vista to work. No matter where i save them, the desktop,the windows folder, the windows32 folder (where all the other screensaver files are) i can not get anything i download to appear on the list of available screensavers.
Help please?
Hey brink, i see your posts a lot around the forums.
When i install the screensavers from wherever, I install them to the system32 folder, but they still dont appear on the list of available screensavers. I cant think of anything else, other than installing most screensavers gives me a .exe instead of a .scr, but i dont think i can get anything else.
Since the screen saver installs by an exe file, see if letting it install using it's default setting instead will allow you to select it from the Screen Saver list. These type install like a program instead of just simply copying a .scr file to the System32 folder.
You may have just got a bad screen saver. You might give the ones from the tip box at the link above a try to see if they may work for you.
