I could use some advice
Atomic Bebop
Rabble Rouser
Hi guys, I am thinking about upgrading my graphics card soon and I'm not too sure which route to go. I have an ASUS P5K-Premium WifiAP motherboard, so I'm all set for SLI. Which is really where my question comes in.
I currently have a GeForce 9800GT, and I'm torn between putting a second one into my configuration in SLI, or purchasing a single, 2xx series Nvidia card. The one I had in mind was a Geforce GTX 275, which is roughly twice the cost of a second 9800GT.
Also, I have a 550W PSU, which should be plenty to keep 2 GPUs, 8GB of RAM, and a Q6600 running.
I appreciate any input here. Thanks!
    Your's Truly
    Q6600 OC'd to 3.138 gHz
    ASUS P5K Premium Wifi-AP Black Pearl Edition
    8192MB DDR2
    ATI Radeon HD5770
    Creative Sound Blaster Audigy II ZS Platinum Edition
    LG Flatron L222WT
    250GB 7200rpm 250GB 7200rpm 320GB 7200rpm 1.5TB 7200rpm
    Corsair 850W
    Antec 900 Ultimate Gamer
    4x 120mm, 1x 200mm, Zalman CNPS 10X Extreme, 50mm NB fan
    Logitech Media Mouse
    Logitech G15 (the old one with the LCD)
    18.4 mbps
    Bluetooth adapter for X360 Controller
Unfortunatley, the P5K isn't an SLI motherboard, as it would need an nforce chip. It can only do Crossfire setups i.e. multi ATI GPUs, so unless you upgrade your motherboard, then SLI isn't an option, sorry :(
A GTX series will still be a great upgrade, though. If the 275's price is your price range, then a GTX260 or 275 would both be a good choice, though I've read and heard the 275 gets a bit too hot when under load.
My two 8800GTS 512s in SLi was recommended a 700w PSU, so you might have been pushing it with a 550w (I rememebr trying a 500w on my 2 and it shut down when under too much load). It *might* be okay for a GTX series card, but don't hold me on that one ;)
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
hm... i would ditch the nvidia :D and go for crossfire or a single...... 4870 or 4890 for now and then add a second later :D
    AMD Athlon X2 5000+ @ 2.6Ghz
    Acer Micro-ATX Motherboard
    ATI HD3870 with 512mb GDDR4
    Realtek HD 7.1 Onboard Sound
    22" Acer X223 Widescreen
    1680 X 1050
    ULTRA X3 600 Watt Modular
    Microsoft Sidewinder X5
    Microsoft Sidewinder X6
    6 Mbs Down 1 Mbs Up
    ASUS Xonar DX
    100Mbps
Pitch the P5K motherboard, spend $200 and get another 9800gt ($99) and an XFX nForce 680i LT SLI Motherboard ($99) or better yet maybe an XFX nForce 750i SLI Extreme motherboard (Also $99). Your system will thank you and you CAN SLI those 9800's. I did and I'm not sorry, check my specs.
    Systemax N2000
    Q6600 (G0 stepping)
    XFX nForce 680i LT
    4 X 2gb OCZ SLI-Ready PC-6400
    Dual XFX GeForce 9800GT 512MB in SLI mode (Stock)
    Integrated High Def audio 192 kHz/32-bit eight channel
    1 24" Septre widescreen, 2 17" Optiquest Q171b's
    1920 x1200 Sceptre / 1280X1024 Optiquest's
    250GB 7200 RPM SATA II
    Cooler Master Real Power Pro 1250W
    n2000
    Thermaltake bigwater 760is - Liquid cooling
    Microsoft wireless laser Mouse 6000
    MicroSoft wireless 6000 v2.0 keyboard
    Wild blue -darn it 1.5mb down and 200k up 17gb p/month FAP
    Windows home server x86(1.5 Tb on 5 drives), Ubuntu 9.0.4 x86, vista x86 sp1, XP pro sp3 x86. SQLserver 2005, MySQL DB 5.0.
depending on which 2 series card your going for it would be better to go that route , first it will be faster and second it will be ALOT less hassle , sli is ok when its working fine but it can be a complete pain in the rear end sometimes
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
    1680 X 1050
    6 Mbs Down 1 Mbs Up
I've had alot of success with this mobo as far as OCing my cpu (pushed it as far as 3.4ghz while keeping a stable voltage and frequency, though it did get a wee bit warm) and have been enjoying the fact that I can use my PC as a wifi hub for my other wireless devices without the need for a router. There are other upgrades I want to look at before replacing the mobo, but this has given me somethign to think about when the time comes.
(I'm kind of kicking myself over the crossfire/sli thing...) Does anyone have any suggestions of a pair of ATI cards that might be comparable to a single GTX275, without breaking the bank?
Thank you very much to everyone who replied to my thread, and for pointing out my blunder Everlong18 ;)
    Your's Truly
    8192MB DDR2
    ATI Radeon HD5770
    LG Flatron L222WT
    Corsair 850W
    18.4 mbps
With only a 550w PSU, a pair of 4850's are probably a good option. Performance wise, it's roughly equivalent to a GTX 285.
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
I like the look of those 4850s... Having one would be a step up from my 9800GT, and then adding a second one later would not be a big expense. and even then, the two of them are cheaper than one GTX285 :)
How do 4850s like being overclocked? Does anyone have any experience with these cards?
    Your's Truly
    8192MB DDR2
    ATI Radeon HD5770
    LG Flatron L222WT
    Corsair 850W
    18.4 mbps
I'm running a rig with an Antec Neo HE 550 watt PS and a single 4850 and I could probably get away with running two 4850's with it, but I'd be more comfortable with at least a 650 instead.
And yes the 4850 is an excellent card for the price to performance you get!
Here's an excellent tool for calculating your power supply requirements - PSU Calculator. Make sure you follow the instructions, especailly for the CPU. Example, though a quad core has 4 cores/processors, it's physically a single processor!!!
A lot of folks choose 2/4 processors when dealing with a dual or quad and then wonder why they get such a high power supply requirement!
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
as far as overclocking it..... i'm not sure its really needed
    1680 X 1050
    6 Mbs Down 1 Mbs Up
