I need help badly please.
pinakfans
I keep getting the windows Malicious removal tool... i guess it comes with windows?
I ran many of my virus scans and they shows nothing.
this shows up System alert: virus Virtob.Win
it pops up randomly...... is there a way to remove it?
I am more than 100% i don't have viruses.
    Toshiba A135-S2345
    1 GB
    140 GB
Hello Pinakfans,
Have you already run a full scan with the Malicious Software Removal Tool to see if it can find anything, or possibly reset it if nothing is found?
Hello pinakfans,
After you have followed Brink's advice -
1.Would you please provide all of your system specs [Just click on this link to do so.]
This helps to ensure all the pertinent information is listed & appears on every post you make.
It then better enables us to help you & saves valuable time, both yours & ours.
2. Please list all of the Security progs that you use.
3. Is UAC turned on?
4.Did your computer have a preinstalled Anti Virus prog?
    1440 x 900
    Laptop / notebook.
    Stock.
    IBM enhanced
    ADSL [ Too slow.]
    Webcam.
Could you perhaps post a screenshot of what MRT has captured?
    Compaq
    intel 965 chipset family
    2 GB DDR 2 SD RAM @ 667 MHz
    On board upto 358 MB RAM
    15"
    160 GB WDC
I haven't had Malicious Software Removal Tool find 1 thing even with full scans in like a year +.Stuff like that I kick to the curb as useless after that long.
    gateway
    intel quad
    8 gig
    nvidia
    realtek
    19' widescreen
    1440 x 900
    581 gb
    High speed Comcast cable
