Solved In Task Scheduler, what's the difference between Create Basic Task and Create Task?
  • Thread starter Thread starter Advice Pro
  • Start date Start date
Re: In Task Scheduler, what's the difference between Create Basic Task and Create Tas
Hello Advice Pro,
While both will allow you to create a task, the "Create Basic Task" is done through a wizard and does not have all of the advanced options as doing it manually with the "Create Task" one instead.
