Index - Enable or Disable
How to Enable or Disable Search Index in Vista and Windows 7
This will show you how to Enable or Disable the Search Index. You may want to disable it to get more accurate search results, or to stop your hard drive from running so much.
The Index keeps track of the files on your computer and stores information about the files, including the file name, date modified, and properties like author, tags, and rating. The index is used to make searching for files in Vista much faster. Instead of looking through your entire hard disk for a file name or file property, Vista scans the index, which allows most results to appear in a small fraction of the time that a search without the index would take.
The Index will run slowly in the background during low or idle computer usage to keep itself updated and current from the changes you make to the files from the locations that you have listed in the index. If you do a lot of changes in these indexed locations, then your search results will not always be accurate until the index has finished updating itself. This can cause the hard drive to run a lot, especially for the first week or so after installing Vista. If you do not do a lot of searches or need very accurate search results, then disable the index to allow Vista to default to using the full non-index search of the drive. The searches will take a bit longer since it is a non-indexed search, but it will cut down on the hard drive running as much and will give accurate search results.
  • Disabling the index may also impact some Microsoft programs, like MS Office Outlook or Windows Media Player, that use the Index when they search.
  • Disabling the index in Windows 7 will cause you to no longer be able to do searches in Libraries. To be able to search in libraries, the Windows Search service needs to be Started and set to Automatic. Libraries require it's included folders to also be added to the index to be tracked properly even though they will still open properly.
  • Disabling the index in Windows 7 will cause you to no longer be able to use Arrange by in Libraries.
EXAMPLE: Index Enabled and Disabled
OPTION ONE
Disable or Enable the Index "Windows Search" Service
NOTE: This will enable or disable the Index for Windows completely. It will not affect the regular non-indexed search feature in Windows.
1. Open the Start Menu, then type services in the search box and press Enter.​
2. If prompted by UAC, then click on Continue (Vista) or Yes (Windows 7).​
3. Scroll down and right click on Windows Search, then click on Properties. (see screenshot below)​
4. To Disable the Index
A) Click on the Stop button. (see screenshot below step 6)​
B) Next to Startup type, click on the drop down menu arrow and click on Disable.​
C) Click on Apply.​
D) Go to step 6.​
5. To Enable the Index
A) Next to Startup type:, click the drop down menu arrow and click on Automatic. (See screenshot below step 6)​
B) Click on Apply.​
C) Click on the Start button.​
NOTE: If the Windows Search service will not start, then leave it set to Automatic and see: How to Fix the Start Error For Windows Search Service to Enable the Index
6. Click on OK.​
7. Close the Service window.​
OPTION TWO
Enable or Disable Index for a Specific Drive
NOTE: This will only enable or disable the Index for the drive you selected.
1. Open the Start Menu.​
2. Click on the Computer button on the right dark side.​
3. Right click on the hard drive that you want to enable or disable Index on, and click on Properties.​
A) Uncheck the Index this drive for faster searching box. (see screenshot below step 6)​
B) Go to step 6.​
A) Check the Index this drive for faster searching box. (see screenshot below step 6)​
NOTE: Step 5 in the OPTION ONE section above will need to be set to enabled for this to work to.​
6. Click on Apply.​
7. Select (dot) Apply changes to drive, subfolders, and files. (see screenshot below)​
8. Click on OK.​
9. Click on Continue in the Access Denied window. (see screenshot below)​
10. Click on the Ignore All button for the Error Applying Attributes window. (see screenshot below)​
NOTE: Vista does not like any attempt to mess with the boot files. This is why you get this error and should select ignore all to skip changing these files.
11. This may take a while to finish depending on the size of your hard drive, so sit back, kick the feet up and relax a bit.​
12. When finished, click on OK to close drive properties window. (see screenshot below step 6)​
Re: Indexing Service (Search)
Thanks Man !
Kinda disliked the Indexing feature , Google Desktop is btter IMO
    Intel
    Nvidia 9650M GT
    Asus N80VN-X1 Laptop
    1280 X 800
    1 X 250GB 5200 RPM
    11 MBPS
Asky,
Your welcome. I always found the Indexer to be a system hog IMO.
    Logitech MX Master 4
Shawn,
Many thanks for the the guide it worked well. just got a brand new laptop today with vista prem. left work early on the pretext that we had a leak in the house. guess i will be playing till the wee hours.
David
Your welcome David, and welcome to Vista Forums. :party:
Enjoy the laptop,
wee hours? heh. I'll be digging through these tutorials forever.
Just the format for these tutorials are nice, and they work.
Thank you once more Vista Forums.
    home build
    AMD Phenom II X4 955
    MSI K9N2 SLI platinum
    4gb
    2 Nvidia 9800gt's SLI'd with 660 core clocks, 512mb ddr3 ea.
    runs thru home stereo, 7.1 channel
    22" Samsung
    c: 320gb maxtor, d: 1tb wd, e: 500gb maxtor, g: 500gb hitachi, 2 external 500gb wd's in enclosures
    750w Corsair
    Zalman
LOL Jerry. I'm glad that you like them. If you notice anything that needs improvement in them, just drop me a PM.
I was looking araound in the services and I found a service with the name NMIndexingService. I was wondering if that also had to do with Windows Indexing.
Quick question on this. I store my Outlook pst file on my local drive. Does this get indexed with this feature? The only real intense searches I do on my laptop are in my email. I'm thinking Outlook indexes/handles these searches, so turning off Vista's indexing still makes sense. Can you confirm?
Hi MadDogAZ,
Outlook adds itself and uses the Index in Vista for it's searches, so turning it off will also turn it off in Outlook.
Your welcome Zebraloc, and welcome to Vista Forums. :party:
I found I've to do both methods to turn the Indexing off completely...
is that any error'll occur while turning off indexing & 0 page files?
please enlighten,thanks Shawn
    XPS 720 RED
    Intel® Core™ 2 Extreme QX9650(Penryn Yorkfield) ([email protected])
    8GB OCZ Reaper PC2-8500 Ver.3@1066MHz
    EVGA GeForce® GTX 295 Plus w/Backplate OC@ 670c/1246m/1500s
    Sound Blaster® X-Fi™ XtremeGamer (D) Sound Card
    Dell Ultrasharp 27" WFP LCD
    1920X1200
    500GB - Seagate 7200RPM, SATA 3.0Gb/s, 16MB Cache with Thermaltake HDD cooler ~ Western Digital 1TB X (5) / 750GB USB 2.0 My Book Essential Edition 2.0 External Hard Drive
    1,000W
    XPS 720 Sliver w/ X-View Clear Side Panel
    Logitech® MX™ Revolution Cordless Laser Mouse
    Logitech® diNovo Edge™
    15MB~D/2MB~U
    Logitech® Z-5500 THX-Certified 505-Watt 5.1 Digital Surround Sound Speaker System ~ D-Link DGL-4500 Xtreme N Gaming Router ~ Scythe KAMA-METER 5.25 inch Bay Multi-Function Panel Controller ~
Hi Abiosis,
It will not hurt anything by turning off (disabling) the Index.
Is it correct that a lot of constant running of hard disk causes it to age off more quickly.
i recently lost a disk. my pc would not read it anymore so will turning off indexing improve h.disk life. I really need to know cause i have the torrent's running about 20 hours a day plus i don't have a ups.
    Amd athlon 64 x2 3600+
    1.5 gb
    Ati x700 pro
    samsung (160gb) IDE hitachi (250gb) scsi SATA
Hi Neon.Dead,
It really depends on if you do a lot of searches or not and prefer the Index search or non-indexed search. It can help if you do not do a lot of searches. If you do, then the Index can help make doing searches quicker and not search the hard drive as long per search, but the results may not always be as acurate.
Hi
I have one question about Indexing and Disabled it from my D drive( My Computer Right Click..as like Option 2 here shown) and i wants to disable it from C drive too if this helps for better Perfomance.But if i disable it.... i will get any Error message for this all the time ??Coz im littlebit worried one mentioned 1000 error ..thats why..
And if i disable from Service windows search what is the Diffrence??
