Soulsnatcher
Dark Angel
Posts: n/a
Microphone Wont Connect
permalink
ok well i got a brand new laptop a dell inspiron and i've been using my
microphone on it for awhile but every time i plugged it in it would have a
pop up asking me if it was a microphone or other things. so accidently i
clicked dont show this pop up again and now my mic wont work properly. what
can i do to make it work right?
Dark Angel
05-14-2007 #2 Doris Day - MFB
06-21-2007 #3 Matt M
Posts: n/a
permalink
![](/proxy.php?image=http%3A%2F%2Fwww.vistax64.com%2Fimages%2Ftealblack%2Fbuttons%2Freport.gif&hash=73c48f97a5400f5e521ad8cf3bd91e5b)
![](/proxy.php?image=http%3A%2F%2Fwww.vistax64.com%2Fimages%2Ftealblack%2Fbuttons%2Fquote.gif&hash=93bea1ecbf8415fda7f538530d6ca60f)
![](/proxy.php?image=http%3A%2F%2Fwww.vistax64.com%2Fimages%2Ftealblack%2Fbuttons%2Fmultiquote_off.gif&hash=8fb36b50c4130640d24091f624b558dc)
![](/proxy.php?image=http%3A%2F%2Fwww.vistax64.com%2Fimages%2Ftealblack%2Fbuttons%2Fquickreply.gif&hash=7611407321767f9cb017c38f819b72a3)
Dark Angel
![post_old.gif](/proxy.php?image=http%3A%2F%2Fwww.vistax64.com%2Fimages%2Ftealblack%2Fstatusicon%2Fpost_old.gif&hash=e1e2febad245e536f4c672ccb1d29b05)
Posts: n/a
> what can i do to make it work right?
You could try sticking some other thing in it and maybe that will fix it.
Love and Kisses,
Doris
Doris
My Microsoft Hero (he loves this company!) ... YouTube - Ballmer
Title Says It All ... Amazon.com: Windows Vista For Dummies: Books: Andy Rathbone
Posts: n/a
"DellCA" wrote:
> The audio card on your computer can detect what is plugged into the
> different audio ports. It does this to try and make configuring your
> computer for something like 5.1 or 7.1 audio output easier. To make
> sure it is configuring things they way -you- want it to be configured,
> it gives you the pop-up to verify it guessed correctly.
> You should be able to turn that back on in the Audio configuration
> portion of the Control Panel in Windows. Since I don't know which
> Inspiron model you have I can't give you the exact location at this
> time, but it is almost guaranteed to be a checkbox that says somethign
> like, "prompt me to verify connected device" or something similar.
> If you have other questions on this I'll be happy to answer them.
> Larry
> Dell Customer Advocate
> Larry
I have the EXACT same problem on the same machine. Although, my Inspiron
model is the 6400
model is the 6400
Vista Home Premium 32 Bit
Re: Microphone Wont Connect
permalink
I have exactly same problem and im on Inspiron 6400 too. I realy heop someone can help us pls"!
permalink
