Installing Vista, need help.
tsarprodigy
Power User
Well, let me start off by explaining how I got into this mess.:D
I was dual-booting XP SP2 and Linux Ubuntu, and I was trying to delete my Linux partition, and i accidentally deleted the entire drive contents, including XP and Linux.:sa: I installed Linux via Live CD
Now, because i dont have recovery disks or a recovery partition I am completely stuck with the very thing I wanted to get rid of, Linux Ubuntu.:shock:
A friend of mine sent me a 3.01GB ISO file of his Vista installation disk. Heres my problem. I dont have, nor can I get, a disk big enough for the ISO file. I have a bunch of 700MB CDs, a 2GB USB drive, a 250GB hard drive (intended for Vista) and a 20GB hard drive (for whatever I may need it.)
How can I install Vista with the information given. It would help so so so much.
I've googled the crap outta this and found only one answer, but I can't use it because I'm on Linux. Help?:cry:
    Compaq
    Intel Pentium D 820 @2.8GHz
    ECS RC410-M (Asterope3-GL8E)
    1GB
    ATI Radeon Xpress 200
    Realtek ALC 888 chipset Integrated High Definition Audio
    Envision EN-780e 16" monitor
    1600x1200
    250GB+20GB
    Compaq SR2050NX
    3 standard fans
    Logitech M-BZ96C Wired Optical Mouse
    Apple Aluminum USB keyboard
    DSL @ approx. 200kb/s
Just buy some DVDs, or alternatively, you could buy a USB drive that is large enough for the ISO (4gb - you won't get a 3gb).
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Hello tsarprodigy, welcome to Vista Forums!
I don't suppose the PC still has the factory installed recovery partition intact?
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
Thank you :) and sadly, no it does not. :cry: This PC was running XP Media Center 2005 with SP2 natively, and i started dual-booting with Linux later on.
Tom
Sadly, I am not able to get either the USB drive or a DVD. If I absolutely have to, I will eventually get one, but it will be a few months out.
    Compaq
    1GB
    1600x1200
    250GB+20GB
    Compaq SR2050NX
    3 standard fans
If you have the time and the inclination, you could try this :
d/l and burn the Vista /7 recovery disc to cd ( I assume you can do that from within Linux).
Windows Vista Recovery Disc Download — The NeoSmart Files
Boot it up. Go to command prompt and bring the 20gb drive online (if needed ) . Initialize to mbr ( if needed ) . Format it ntfs.
Boot back into Linux, and use 7-zip Linux version to Download to extract the Vista iso contents onto the 20gb HD.
Boot up the Vista/7 recovery disc, navigate to setup.exe on the 20gb drive and run it.
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
Thanks so much. I will definitely try that. First, I'll format the drive as NTFS in linux then try extracting via 7-Zip.
And I'll be sure to try it exactly the way you suggested afterwards, and i will definitely get back to you. :) Thanks Bro
    Compaq
    1GB
    1600x1200
    250GB+20GB
    Compaq SR2050NX
    3 standard fans
Ok, I did as you said. Just one problem. It asks for a product key. I used mine and it said that the key was invalid or could not be verified.
    Compaq
    1GB
    1600x1200
    250GB+20GB
    Compaq SR2050NX
    3 standard fans
you said you originally had XP MCE Edition right? and you now installed Windows Vista?
you must have a vista product key to use windows vista, unless you want to run windows illegally.
    AMD/GIGABYTE
    AMD Athlon(tm) 64 X2 Dual Core Processor 6000+ (2 CPUs), ~3.
    Gigabyte GA-M57SLI-S4 (rev. 2.0)
    2048MB RAM
    NVIDIA GeForce 8600 GT
    SyncMaster T220/T220G,SyncMaster Magic T220/T220G(Digital)
    1680 by 1050 pixels
    Seagate ST310003 40AS SCSI Disk Device Western Digital WDC WD50 00AAJS-00YFA SCSI Disk Device
    Thermaltake 500W
    VERY FAST>>>>!!!!
    Optiarc DVD RW AD-7191S SCSI CdRom Device
yes that is true. Ok, how can I get said Vista Key?
    Compaq
    1GB
    1600x1200
    250GB+20GB
    Compaq SR2050NX
    3 standard fans
well if your friend no longer has his copy of windows vista installed and its the same edition you installed on your computer, ask him for his key. i think this is legal, other than that you have to contact microsoft and buy a product key from them.
Microsoft Volume Licensing - Activation Centers
    AMD/GIGABYTE
    2048MB RAM
    1680 by 1050 pixels
    Thermaltake 500W
    VERY FAST>>>>!!!!
This will work if it is a full retail key and it is not currently in use on another PC, 1 retail key = 1 install on 1 PC at a time.
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
I bought an eMachine a few years ago that came with OEM Vista Disc (not a Recovery Disc) and product key on the back. That computer was so slow and horrible that I gave it away. I kept the 250GB hard drive it came with and replaced it with an older 60GB hard drive and installed Ubuntu on it.
I kept the Windows Vista OEM Disc and the product key. I built a PC and installed Vista using that OEM disc and when it installed and Windows loaded and was asking me for activation I entered the product key and it worked.
I hope that was OK and legal.
If you use a Vista Retail disc, I don't think that OEM key would work.
That's why I said if his friend doesn't have it installed on his computer, ask him if we would give him the product key.
    AMD/GIGABYTE
    2048MB RAM
    1680 by 1050 pixels
    Thermaltake 500W
    VERY FAST>>>>!!!!
Microsoft Volume Licensing - Activation Centers[/QUOTE]
hmmmmm... I'll see what I can do. I think he upgraded to 7 so i might be good then. Thanks :D
    Compaq
    1GB
    1600x1200
    250GB+20GB
    Compaq SR2050NX
    3 standard fans
