Here's a mini tutorial for installing the Xbox 360 wired controller if you're having a driver problem.
I was having a small driver problem when connecting the Xbox 360 wired controller to my Vista x64 Home Premium machine. There were two instances of the controller in the Device Manager:
1. Xbox 360 Controller for Windows
2. Controller (XBOX 360 For Windows)
I downloaded the drivers for the controller from the MS site: Download Gaming Software
Once I installed the MS drivers, the device "Xbox 360 Controller for Windows" was successfully installed, but the other device "Controller (XBOX 360 For Windows)" would not install the necessary driver. Even Windows Update couldn't find the appropriate drivers for it.
So if you are having this same problem, follow these steps:
1. First download and install the MS drivers from the link above. Once installed, connect your Xbox 360 controller to your PC and it will install the driver for "Xbox 360 Controller for Windows" but it will not find the driver for "Controller (XBOX 360 For Windows)". It will say that it failed to install the driver for that device, but that's okay because we are going to fix that now.
2. Open Device Manager (Start Orb -> right click "Computer" and select Properties -> click Device Manager on top left)
3. "Controller (XBOX 360 For Windows)" should be under "Other devices". Double click on it then click on the Driver tab.
4. Click on "Update Driver".
5. Click "Browse my computer for driver software".
6. Click "Let me pick from a list of device drivers on my computer"
7. Scroll down to "Human Interface Devices". Select it and click Next.
8. Leave the Manufacturer as "(Standard System Devices)" and in the Model pane, select "USB Human Interface Device" and click Next.
Windows has successfully updated your driver software
Congrats! Now you should be able to find your Xbox 360 controller in "Game Controllers" in your Control Panel.
Note:: The device that was labeled "Controller (XBOX 360 For Windows)" is under "Human Interface Devices" in your Device Manager with the name of "USB Human Interface Device". If you need to find it, double click on the "USB Human Interface Device"(s) you may have and the Location: entry will tell you which one the controller is.
I have made this as simple as possible so that even the most basic computer user could follow my steps to a successful install. Hopefully this will help you as it did me.
 - E6750 @ 3.2GHz
 - Asus P5K-e/Wifi-AP
 - 4x1GB Crucial Ballistix DDR2 800
 - PNY 8800GT @ 675/1675/950
 - Asus Xonar DX
 - Samsung SyncMaster 220WM
 - 1680x1050
 - 500GB WD SATA II 500GB Seagate SATA II
- PSU
 - 700W OCZ GameXStream
- Case
 - Cooler Master Centurion 5
- Cooling
 - Arctic Cooling Freezer 7 Pro
 - Logitech G5
 - ~3Mb
