Hello.
It looks like since i updated Vista with SP1, i'm experiencing paquet loss.
The motherboard is a Tyan 5400xt. (bios Updated to 1.01 - Latest stable)
My cable modem box (ISP one) is on 192.168.1.1.
When i ping -t 192.168.1.1
i have about 30% paquet loss !
I changed the cable, the port on which the cable is plugged.
Disabled IPv6 etc ..
It still happens.
When i do the same test with another computer @home (running vista 32, 3Com chip Lan) No probelm !
Prior installing this 5400xt, i was running a K8we, vista Ultimate x64 SP1 same cable, same switch port : No problems at all.
So i suspect some bug / incompatibily with this Lan chipset and Vista.
I'm running MS drivers because i cannot install the latest Intel Lan drivers.
When I want to install them, it stops with a "software not compatible with this version of windows".
Here are my plans:
Boot a linux live Ubuntu : ping -t and see if it'shardware related or soft.
Then (i suspect soft) Reinstall Vista from Scratch. Update just before SP1.
Install Latest Intel drivers ( i was able to install them prior applying SP1, but after SP1 it starts to behave strangely and when i wanted to uninstall these drivers to test with MS drivers i was not able to uninstall - software incompatible with this version of windows).
Any advice / idea welcomed.
Regards.
It still happens.
Here are my plans:
Regards.
