Internet problems
seifermd
Hi all,
I'm having the weirdest problem with my internet at the moment. I typically use Internet Explorer and it runs fine and I can access websites etc. However after a given time period (maybe 30mins), it stops connecting me to webpages and just does this "forever loading" thing. I thought it may have been a software issue so I installed Google's Chrome but that does exactly the same thing.
I don't think its a problem with the router/modem because I still have the problem even if I restart that. Same if I repair my network connection. I've tried deactivating firewalls and antivirus software but to no avail. The only way I've managed to overcome the problem is if I restart my computer and obviously restarting my computer every 30mins is less than ideal.
If anyone has heard of a similar thing or can recommend trying something to fix it, I would be very appreciative. Many thanks!
Michael
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
Thanks for the response.
I've tried resetting Internet Explorer and running it without add-ons, however none of these fixed the problem. As I mentioned I have the same problem with Google's Chrome, so unless they share some component I don't think the actual problem is just within the add-ons or the software settings. :confused:
Does Firefox have the same problem.
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
i'm having a similar problem with IE. just started this week. Either a windows update, or i'm thinking yahoo toolbar. i may disable it in addons to trouble shoot it.
it really ticks me off when i get those white outs and it doesn't respond.
Yeah that's it, although rather than Yahoo I use the Google toolbar. It began only in the last week or so and it could quite possibly be from a Windows update. I just wish someone knew something because simply describing this problem as frustrating is a huge understatement!
mine is still hosed. yahoo toolbar has a mind of it's own also. it keeps disabling itself. the only reason i installed it was to access yahoo mail instead of windows mail to click mailto: links. I think windows mail is hosing it, because it keeps coming up instead of yahoo (i never set windows mail up) and yahoo is nowhere to be found in programs or default programs to set it once and for all for my mail.
what a mess lol!
Well at the risk of jinxing myself, it seems like my problem has sorted itself out. While I wasn't aware of any change (updates or change of settings) I'll certainly take it without questions. I hope you have similar success, good luck! :confused:
Try three methods:
1.Run Command Prompt (cmd.exe) as a administrator and insert:
netsh winsock reset +restart
2.It could be also wrong work non-system firewall (if you have) - uninstall non-system firewall completly,turn on system firewall and check results
3.It could be also defective drivers for network card - update it if you can
I to am having this issue but only really noticed it lately. I tried downloading a 60+mb NVIDIA driver update today and it took well over an hour whereas before it would have been minutes. :mad:
My Firefox or Chrome (don't use IE) stalls on webpages and forget web videos when this starts to happen.
I run a home network through a router where my Vista PC stalls/lags but the other 3 XP machines (2 desktops, 1 laptop-wireless) have no probs. I know this as my sons' would be yelling while gaming if they had this 'lag'.
Hi Michael,
Try using Internet Problems
Let me know if this works for you.
I've followed your link Sebsworld and unfortunately it all came in good. :confused:
Anyone have any ideas as to why after 20-30 mins of online browsing Vista seems to stall/lag?
Run these two commands in an elevated command prompt.
netsh int ip reset log.txt
netsh winsock reset
Disabe IPv6 by adding this reg key
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip6\Parameters and create (if it doesn't exist) a new Dword called "DisabledComponents" and put either 1 to disable tunneling adapters or 255 to disable IPv6 completely.
Those will help with a lot of issues but if it doesn't help try disabling from startup(via msconfig)/uninstall your AV/FW and see if that helps. If you torrent a lot disable uTorrent (or whatever client you use) from loading at startup then restart and see if you still have the problem.
