Solved irql_driver_not_less_or_equal
jonsan86
This is my first time posting here and I hope I am doing this right. I usually get the BSOD with the error message irql_driver_not_less_or_equal whenever I download a large file or try to go online with my xbox 360 that is using a bridged connection from my PC.
I am using Vista x64 OEM I have had this computer for about 2 years now.
I have attached the minidump after the most recent BSOD. Any help would be much appreciated, thank you!
Welcome
I normally handle the BSODs at Vista. While I am away for a few weeks and do not have the required software, I will refer any BSODs to those with expertise in the Seven Forum.
Im asking my friendes at the Seven Forum to take care of this. Just be patient. You will be helped by an expert in the field
It appears that your Realtek Ethernet drivers are the cause here. Please install these updated ones: Realtek
If the BSODs persist, remove Daemon Tools. Then, remove SPTD with this tool: http://www.duplexsecure.com/download/SPTDinst-v174-x64.exe
Code:
Rtlh64.sys      Tue Sep 26 07:20:23 2006 (45190CF7)
sptd.sys        Sun Oct 11 16:55:14 2009 (4AD24632)
...Summary of the dump:
Code:
[FONT=lucida console]
Built by: 6002.18267.amd64fre.vistasp2_gdr.100608-0458
Debug session time: Sun Dec  5 23:27:18.063 2010 (UTC - 5:00)
System Uptime: 0 days 9:45:42.008
*** WARNING: Unable to verify timestamp for Rtlh64.sys
*** ERROR: Module load completed but symbols could not be loaded for Rtlh64.sys
Probably caused by : Rtlh64.sys ( Rtlh64+69d7 )
DEFAULT_BUCKET_ID:  VERIFIER_ENABLED_VISTA_MINIDUMP
BUGCHECK_STR:  0xD1
PROCESS_NAME:  System
FAILURE_BUCKET_ID:  X64_0xD1_VRF_Rtlh64+69d7
[/FONT]
    Jonathan King
    AMD Athlon Dual Core Processor 4850e overclocked @ 2.92 GHz
    ASRock A780 FullDisplayPort
    6.0GB Dual-Channel DDR2 290MHz Crucial Technology
    ATI 3200 (onboard), nVidia 7200 GS (PCIe)
    17" Cybervison ds69T, 17" Starlogic
    1024x768
    WD 320GB SATA, Hitachi 1TB SATA
    Antec ea-430d 430W
    Antec 300
    stock cpu, 120mm rear, 140mm top
    Microsoft Wired Desktop 500 (USB)
    Microsoft Wired Desktop 500 (PS/2)
    9.32 Mb/s download; 0.36 Mb/s upload
    Other OS's: Windows 7 Professional x64, Windows Professional x86, Ubuntu x64
So I guess you liked the expert that I sent. He really is good at this. Good luck to you
