Is my Laptop Running at its best?
Fastboy42
Banned
Lately my laptop has been running like a slug and I'm sick of it. I was thinking of getting more RAM, but I don't know if my current RAM is the best for my laptop.
Here is a link to the default specs of my laptop.
Toshiba Satellite Pro L300 (PSLB1A-01L019) PC Notebook - Product details and features - DealTime
Here is what my current RAM is.
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR2
Module format SO-DIMM
Manufacturer (ID) Hyundai Electronics (AD00000000000000)
Size 1024 MBytes
Max bandwidth PC2-5300 (333 MHz)
Part number HYMP112S64CP6-Y5
Serial number 00002002
Manufacturing date Week 20/Year 08
Number of banks 2
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 3.0-3-3-9-12 @ 200 MHz
JEDEC #2 4.0-4-4-12-16 @ 266 MHz
JEDEC #3 5.0-5-5-15-20 @ 333 MHz
____________________________________________________
DIMM # 2
SMBus address 0x52
Memory type DDR2
Manufacturer (ID) Apacer Technology (7F7A000000000000)
Size 2048 MBytes
Part number 78.A2G72.9K5
Serial number 02308315
Manufacturing date Week 32/Year 08
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
    Toshiba Satellite Pro l300
    Intel(R) Celeron(R) CPU 550 @ 2.00GHz
    Intel Corp. 88395664Q
    DDR2, PC2-5300 (333 MHz), 1024 MBytes, Hyundai Electronics,DDR2, PC2-5300 (333 MHz), 2048 MBytes, Ap
    Realtek HD Audio
    Matte screen
    1024 x 768 x 4294967296 colors
    120gb SATA 2.5inch FUJITSU MHZ2120BH G1 ATA Device
    Notebook
    Fan cooled
    Logitech Cordless Optical
    Logitech Cordless Desktop EX110
    256Kbps
    I like Spore,Rabbits and I'm a Computer Freak.
Have you tried just doing a defrag with disk cleanups to see if that helps at all?
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
Hello Fastboy42,
I would have to agree with Everlong18, try a good clear out of all the rubbish that seems to accumulate over time.
I would do the usual,
CCleaner - Download
Malwarebytes.org
Disk Defrag - Reclaim the Speed Of Your Disks
Also take a look in "msconfig", see what is in the startup tab, is there anything there you can stop ?. (anything you stop from loading will be enabled when it's needed by the OS).
The thing with adding more memory is, you don't always get the boost you hoped for.
Try this first, it's a lot cheaper too.
Good luck and post your results.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Surprisingly I already have all those programs and I have tried that. Will an extra 1gb RAM benefit me?
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR2
Size 1024 MBytes
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
DIMM # 2
SMBus address 0x52
Memory type DDR2
Size 2048 MBytes
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
How slow is slow? Maybe the harddrive is running in PIO mode and not
DMA. Sometimes the machine will switch modes. Check Device Manager Ide ATA/Atapi controllers.
nope,
thats all good. It seemed to have sorted itself out:eek:
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
mine can handle 4gb.
I have a 1gb and a 2gb. Should I jump to 4?
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
3GB or 4GB - it is nearly the same because of the address space for the RAM will stop at 3.2 to 3.4GBs. Maybe I first misread your specs - missed that you have 2 dimms.
    Dell
    Q6600
    HP w2207h
My laptop wouldn't handle x64 would it?
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
No 64bit with the Celeron processor. You cannot expect too much from a 2GHz processor if it is a single core. It`s OK for surfing, mail and office. But beyond that it will be difficult.
    Dell
    Q6600
    HP w2207h
Definitely get more ram. Vista is a ram hog and if your running it with 1gb of ram, its going to appear slow. Upgrade it and you'll notice a big difference :)
    HP
    Intel Neo
    2GB
    Intergrated Intel Graphics
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
    Down: 16mb/s Up: 1.6mb/s
    I killed my HP Laptop :'(
I am running windows 7 and I have 3gb of RAM:D
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
um...
I had windows 7 and 3gb of ram all along
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
um...
Haha, about that... :o
Reading back I see that you said it sorted itself out. I did notice though that the RAM is from 2 different manufactures.
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
yep,
1gb was in when I bought it and I added the other 2gb
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
You probably already know that RAM works best when its the same exact chip from the same brand.
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
indeed...
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
