Keep taskbar on top - keeps unchecking
drainey642
Has anyone experienced this problem...
I'll open a program window and the taskbar disappears. It's not an auto hide property. When I check the properties the checkbox to "Keep the taskbar on top of other windows" is unchecked. I'll correct the problem but within as little as a few minutes the same thing will happen.
Thanks for any help you can offer.
~D
Hello Drainey, and welcome to Vista Forums.
You might see if running a sfc /scannow command may be able to fix it. If not, then you can do a System Restore using a restore point dated before you had this problem.
