Keyboard problems
patch41
Vista Pro
Hi folks. My keyboard is notworking properly, i can type words, but the numbers are not working, I keep getting this popup box saying guarded id keyboard driver is not working, driver is not responding, guarded id is now turned off, I went into device manager and it said the drivers are up to date, any help would be appreciated thanks, Patch41
Hi Rich, It is some kind of a key locker, It comes with norton, its something new they added with xfinity, I did have some kind of a virus yesterday which i got rid of, but you would think they would give you some kind of a clue on how to straighten the keyboard out again, I went into programs and deleted it, and everything seems fine, Thanks again rich...patch41
(tipped the scales)
First thanks for the rep.
To be safe, run a full anti virus scan
Run a full malwarebytes scan and download and run a full scan with
super anti spyblaster. Just want to be sure that that virus or spyware is gone. My big concern is a keylogger.
Lets be sure patch. Dont want you to be sorry later on. If all checks out ok, you are good to go.
