NicklasSchouw
First i would like to say hello first time here :D
And then i would like to say sorry if im not spelling correct because im writing this very fast.
Well the problem is: Im installing windows 7 and i just bought it and all that crap. Then i try to install it and i CANNOT custom install it because i dont got an external harddrive to put my stuff on so i will need to do an upgrade..
Okay i start install and click upgrade and get the message "You can’t do a typical upgrade using an installation disc that’s different from the language installed on your computer. Go online to see how to install Windows 7 and keep your files and settings."
I must /american. so on with the story. Well i think i will just go online so i do .. BUT no solution to MY particular problem there..
sad face!
So i go and search on it on google and i find a place where i can download and install MUI language packs and so i download it and try to install it BUT again a problem and this time its titled "The limited amounts of languages is already installed" SO i think F%#k what should i do and then i found this page "yay" :D
I got and Packard Bell pc and i run with Windows Vista Home Premium 32bit service pack 2 installed in Danish :D
Greetings from CPH and HOPE :D
sad face! So i go and search on it on google and i find a place where i can download and install MUI language packs and so i download it and try to install it BUT again a problem and this time its titled "The limited amounts of languages is already installed" SO i think F%#k what should i do and then i found this page "yay" :D
