not quite an overclocking question but i figured you guys would probably know what to tell me haha
i have an hp dv6238 laptop
intel dual core t2250 1.73GHz cpu
(not sure exactly what other info you need, do let me know. i have everest and can pull most right off there. unfortunately chipset comes up as "unknown" but if you can tell me another way to find it i'll do so.)
i'd like to upgrade to something
"2.6 GHz Pentium D CPU, or 1.8 GHz Core 2 Duo, or equivalent"
having read the dv6000 (which seem to all use the same motherboard) maintenance/service list it suggested intel t7200 as the top (unsure if its top in terms of what was available when it was written or top in terms of what this system can support) but i've had mixed comments on whether its actually compatible so i'm at a loss
any help would be greatly appreciated
ideally i'd like something thats pretty much a "drop in" replacement that wont require me to change everythign else and in effect cause me to have to rebuild the entire computer (at which point i may aswell get a new more up to date one since this is about 3 yrs old now hahaha)
thanks again all
thanks again all
