You should upgrade or use an
alternative browser .
Solved Log on screen help
I was fiddling with an application that logs you on by using face recognition but i decided to remove it as i just wanted to play with it.
Now my log on screen makes me click my name before i can enter my password.
how can i get it back so i dont have to click my name?
thanks
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
Galaxy S23 Plus phone
Operating System
Thanks but not quite what im after. i still want to have to enter my password.
that's what i want it to look like after i have turned it on.
Do you have any other user accounts displayed at log on?
To have only your user account display like above, you will only be able to do so by having one user account on the computer. The facial recognition program may have created some sort of guest or other account for it to operate, and didn't get completely removed.
Another option is to have to type in both your
user name and password at log on .
Operating System
Operating System
There was another user on there, but that's gone now and the guest account is still inactive.
Fixed it. I made a new account, logged off, logged on then deleted that account.
Cheers for the help guys
That's great news. I'm happy to hear that you got it sorted.
Operating System
Operating System
