bigfish79
i have a msi Motherboard with a amd dual core 6000 hypr link , a 9500 gt evga 1 gb pci exspress card and a nvidia 10/100/100 net driver (all drivers are current and upto date i am very positive about that )
about 3 weeks ago my upload speed went from 170 kbs down to 106 kbs i have a 2wire 38000 hgv-b adsl modem with a lan line connection and a 18 MB connection threw At&T Uverse and they cant figure out what the problem is
they have tested the line and replaced the modem 2 times in the last 2 weeks
ive tested the connection on every speed test there is on the net and they all come back with the same results
according to the config on the modem i have
• Incoming: 25216 kbps
outgoing : 2024 kbps
now speed test results are this
down speed :2031 KBps
up speed : 107 KBps
3 weeks ago the up speed was at 175 - 180 KBs
the down speed is fine i hit well over 1.3 Mbps and the up speed is whats the problem seeing as i own a shoutcast server radio station and was able to send up 124 KBs and still get almost a 1 MBps down speed
now i cant even go over 56 kbs up or i wont be able to use the internet or it will be realy realy slow
im just woundering if a 18 MB connection from Uverse is the problem or if i did something ,or if this seems like a isp lie in speed and should tell them to go F@ck
themselfs and find a new isp
any ideas or help would be much appreciated
up speed : 107 KBps
themselfs and find a new isp any ideas or help would be much appreciated
- Home made BY MFE (Mudfish Enterprises)
- AMD athlon dual core 6000+ w/direct connect /hyper transport
- MSI K9N SLI V2
- 6gigs 2 sticks at 2 gigs each 2 sticks &1 gig each
- Navidia GeForce 9500 gt 1 gb ddr232 bit
- 24 bit 6channel Fion
- Acer E151H
- 1440 x`900
- 2 sata WD at 500 gigs each and 1 externsl at 320 gigs 1 sata WD @ 260gigs 1 sataWD @ 120 gigs
- Case
- Super case black
- Microsoft Comfort Optical mouse 3000
- Logitech classic 200
- AT&T Uverse Fiber optic 18mb
- Other Info
- plus a boston accustic surround sound systeme to blast my radio station MFE @ at www.tmts.org.uk
