My computer is driving me crazy...it doesn't make sense, when there is no application running, it is using so much memory, and the core temperature ranges from 80-95 degrees Celsius, and the highest its gone is over 100, when I was doing absolutely nothing to it.
When I try to put it to sleep, it won't go to sleep, the monitor gets ready for sleep, but the computer is like full blown using so much and making SO MUCH NOISE, that it stops itself from going to sleep and stays on. When I start using programs and stuff like photoshop, sometimes it calms down to 30-50 degrees C, it just doesn't make sense to me. (or maybe it could be that whatever devil that is causing this stops when I happen to be using programs).
I have an HP windows vista 32 bit home, AMD athalon 64 X2 dual processor 4400 + 2.30 GHz
1918 MB of RAM
and when I open my task manager, it is using 83 processes, CPU usage is around 60%, Physical memory: 55% (and right now the only thing I am using is google chrome) I just closed everything and checked, and it went down to 80 processes, and the same amount of usage and memory.
Usually the most memory guzzling process is my cheap little anti-virus program using around 52, 652 K of memory (I don't know if that's a lot? the google chrome is using slightly less than that, so I doubt it)...and Host process for windows services which leads to a bunch of crap that I don't understand. This is absolutely ridiculous, Vista is evil. Do I have a virus or something?
As I am writing and preparing this question, suddenly the core temp dropped from over 90 degrees to just over 40, and the noise stopped, however on processes it is using 80 (a few less than what it was before, so something stopped), and the highest memory using processes like my anti-virus program is still the same...so I'm not sure what that thing is? PLEASE HELP, this happens 90% of the time it is so annoying and stressful because of the noise.
1918 MB of RAM
