Low Disk Space over and over
I had to reinstall Windows Vista Home Edition and I formatted the 10 gig drive which holds the OS and yet now it keeps overfilling the space. I have even compressed the drive and I have not installed several software titles which were on before with no space issues.
Can anyone tell me why this crappy machine is doing this to me?
    Dell
Hello vissyvista, welcome to Vista Forums.
Surely you can't mean a 10GB hard disk drive (HDD) that's not even big enough for Vista, let alone any other programs/apps to be installed to. Have a look att the tutorial at the link below and post a snip of computer like mine below so we can see what you have.
How to Post a Screenshot
click image to enlarge
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
If you really do have Vista on a 10GB partition there's nothing you can do to free up more space short of creating a bigger partition and re-installing Vista to that.
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
Pre reinstall, everything was on the 10 gig partition and now it barely can hold Vista and critical programs. This is stupid.
It is giving me the Low disk warning right now.....aaaaaaaaaaaaahhhhhhhh.
It took forever to get to this point because I hade to also download 100 updates.
    Dell
Dell sold you a PC with Vista pre-installed to a 10GB partition?
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
to can merge both drives together.. which will allow you to stop getting the low space error
I can't understand why we do need two partitions
follow these instructions
Resize a Partition for Free in Windows 7 or Vista
Windows 7 and Vista include a built-in functionality in Disk Management to shrink and expand partitions. No more 3rd party utilities needed!
To get to this utility, open up Control Panel, and type in partition into the search box.. you’ll immediately see the link show up:
Shrink a Partition
In the Disk Management screen, just right-click on the partition that you want to shrink, and select “Shrink Volume” from the menu.
In the Shrink dialog, you will want to enter the amount you want to shrink by, not the new size. For example, if you want to shrink your 50gb partition by roughly 10gb so that it will now be roughly 40gb, enter 10000 into the box:
Extend a Partition
In the Disk Management screen, just right-click on the partition that you want to shrink, and select “Extend Volume” from the menu.
On this screen, you can specify the amount that you want to increase the partition by. In this case, I’m going to extend it back to the roughly 50GB size that it was before.
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
