nah if you take it to a shop they'll just charge you to reformat it , thats a last resort , whats the make and model of your laptop ill see if i can get some info on exactly how to do the repair install , it'll be easy once you know how you just need to find out what button to press at startup , then instead of booting up into windows it will take you to set of options to either reformat or perform a repair install , im assuming here you have a recovery partition on yuor hard drive.
see im thinking a repair install wil fix the registry , and as its only a repair option and not a reformat you wont loose any files.
Its a last resort on my part tbh im running out of ideas , if this doesnt work you may have to reformat and if that doesnt work you may need to take it to a shop to get a new drive fitted , but try yourself first and save some cash
you never know some clever arse may happen acros this thread and tell yuo its something really simple , but im thinking not
- Custom Build
- Intel Q9550 @ 4Gig / Titan Fenir
- XFX 780i
- 4GB OCZ PC2-8500C5 DDR2
- Gainward GTX260/216 SLI
- Creative X-FI Xtreme Gamer
- Dell UltraSharp 2209WA 22"
- 1680x1050
- western digital raptor 10000rpm sata
- PSU
- OCZ Modstream 700w
- Cooling
- Titan Fenir
- Logitech G5 Gamer
- Razer Reclusa
- 8mb
Good luck
nope still not working! so after all that hassle nothing! So now im guessing it really is buggered! Am i right in guessing i now need a new drive thingy? And also where do i get one and again would u know roughly how much i would be charged to get one fitted! was in pc world a few month ago and asked about it getting opened up and cleaned out and they said they would have to send it off to someone whos insured to do that and it would cost well over £200! so to put in a new driver thing im guessing it has to be opened also costing £200 +???
