Ok - First let me apologize for posting in general...I dunno where else to post this.
OK heres the deal, Basically I messed up big time. I was increasing my virtual memory in my PC and when i was there set my C: to active. When i rebooted my PC i got a BOOTMGR is missing.
So i went into repair via Vista installation disks and through the command prompt typed 'Bootsec /fixboot' then rebooted.
Then it said booting but didn't move.
Then i decided to give up and do a reinstall, at expanding files i got the error Windows cannot install required files. Make sure all files required for installation are available and restart the installation. Error Code 0x80070001
The disks work on other PC. So i decided to do a drive format, It completed successfully...So it said anyway. Install failed again.
Any suggestions?
Note
Please help - Thanks
Any suggestions?
Please note, I think this is important - I Had 256-Bit AES encryption on my drive via truecrypt.
- Hewlett Packard
- 3.40Ghz / 2.20Gz Duo Core
- 2GB / 3GB
- 160 GB / 160 GB
