mbr help?
freeman
I, uh, couldn't figure out where this should go so I'm just gonna put it here.
I dual boot vista ultimate and win7 (build 7000) on my laptop (both x32) and the vista installation ksod'd me. I had to wipe the vista partition and reinstall vista. apparently the mbr was on the vista partition and was wiped out also. now with the new vista installation there was a new mbr and win7 is not registered in it. i don't get the choice to boot into win7 when i start up my computer.
can anyone point out a way to solve this problem for a computer n00b? (that is, a way short of wiping win7 and reinstalling it too)
thanks mucho
Rebuild the BCD with the 7 Disk (Startup Repair so that is sees 7 and vista and gives the dual boot option) What occured is when you re-installed Vista you overwrote the Boot config for Win 7- now you have to mark 7 as "Active", and then repair the Win7 boot data.
Follow steps here for marking a partition (volume) as Active.
More info here: http://www.vistax64.com/tutorials/163304-dual-boot-using-free-partitioning-software.html
http://www.vistax64.com/tutorials/194765-system-recovery-options.html (same process-but you will use Win7 Disk instead of Vista disk to perform the Startup repair- you may have to do this twice)
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    Wireless Microsoft 3000
    10 mbps/2 mbps
