Hi guys,
having 2 gb of 1333 mhz DDR3....apparantly not enough if disabling the pagefile. So i bought 2 more sticks some 5 weeks ago, installed it and every 5-10 min i had a "hang-up" and needed to force down and then restart.
Needed to remove the memory and then i saw it. It clearly says on the sticks 'OCZ3G13332GK' (the first G is for Gold), should have been 'OCZ3P13332GK' (the P stands for Platinum). The only difference here is the latency speed. So i returned the memory and yesterday i got the right one.
Surprise .... surprise, 'hang-ups' are back.
So the question : does anyone know if there is a problem with the memory when handling 4 sticks or could it be the Asus board? (P5K64 WS MB S775 Fsb1333 Q P35 4DDRIII13 4xPe16).
I opened the case the first time i had problems put a fan before it, this did not make a difference. Didn't try this now.
thanks
François
PS
t
the 5 weeks because it took a while to get the stuff
thanks
François
PS
t
