Microphone not working
DonnyM
Hey, I recently Got vista home premium 64 bit and my microphone is not working.
It says microphone is connected and working. (not a headset), but it is not recieving any sound. My speakers do work.
I have a x-48 ds4 motherboard, by the way.
All drivers are updated, it just doesn't work.
Any help would be appreciated.
Thanks
Hi, DonnyM, and welcome to the forums.
Either try that mic in another computer or try another mic in this computer....
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
One other thing - make sure the mic is not muted in your Sound properties (I always forget to tell people to look for that)
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
my other mic doesn't work either.
my Mic isn't muted under properties.
Sorry, Donny, I was out of town for 3 months - for some reason the mic jack seems to be shot, since the actual driver is installed *and* the mic actually shows in the sound properties- but have you tried uninstalling and then re-installing the drivers?
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Thanks
Hi DonnyM,
Have you updated your Realtek audio drivers from the manufacturer`s site here?
Realtek
Uninstall your current verion and reinstall with this version then reboot, afterwards It should make the Microphone input work correctly ;)
Steven
Re: New Realtek HD audio driver update
Guys need help, i'm frustrated (or how do you spell it).
i viewed all 36 pages with hope to find the answer but i didn't.
my problem is with the microphone.
when i plug it in a popup pops and say that i conected something in the mic socket.
the audio device manager from realtek is poping the device selecting window where i select that mic was conected.
after that nothing happens, i mean the mike is not working.
i tried to play with the settings in the audio device manager and all i get is just some noise from the speakers (playback niuse) when i try to speak to the mic i can't hear nothing at any volume ranges, tried the boost and nothing happened tried to reise the volume in the speakrs out settings and they are all maximised.
tried to install reinstall all kind of driver versions and nothing same annoying noise.
i have Vista x86 ultimate
intel core2 quad q6600
2 GB ram
and gigabyte mother board GA-P35-DS3L with alc888 realtek audio chipset.
pls help me it's driving me crazy.
best regards,
Rodman
i have the exact problem with my microphone.
tried many driver versions ans still the same result.
pls help me with that.
i've posted in another thread with all the specifications of the problem.
best regards,
Rodman
Rodman, did you read the rest of the thread, and try the mic in another computer or another mic in this computer?
And please don't post *problems* in a sticky (informational) thread.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Yeah I've done it
Now my microphone works perfectly
I'm writing this message with the E speaking program
Just remember in the configurations of the microphone not to use the filters of the microphone like noise suppression and acoustic
forgot to tell what was wrong.
My microphone work from the front jacks, i read somewhere that there is some problem with these front jacks and if you disable them from the sound control panel they started to work.
so press the little folder icon in the audio manager a set "disable front jack detection"
after i've done that my mic started to work.
Best regards
Rodman
