Missing hard drive
I am hopping someone can help me This is my second hd in less than a month so i am thinking there is another issue
I am running Vista Home Premium with 3 1tb sata drives and all my media is on drive E: well it has disappeared I have no more video folder and when I go to my computer it is gone but when I restart my pc it is back for a little while then it disappears again this has prompted me to buy a new drive but that did not fix the issue
any help is greatly appreciated
Thanks !
When you go to device manager is it showing there?
When you right click computer and go to manage,storage,disc management
is it showing here?
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
    LENOVO 64734VM
    15 inch
Could you please take a snapshot of Device Manager as it opens to you.
What I mean is don't expand anything just open it and take a snip.
If anything is already expanded it means there is something to fix in the expanded section.
    LENOVO 64734VM
    15 inch
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    40 Meg
    LENOVO 64734VM
    15 inch
Sounds good,hope it stays that way
    LENOVO 64734VM
    15 inch
When it disappears is there anything in Event Viewer to indicate a change occurred.
It would be under Administrative events.
    LENOVO 64734VM
    15 inch
Yes set a restore point and do this.
press Windows key and R
Type regedit, and then click OK.
If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
In the navigation pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
In the right pane, click UpperFilters.
On the Edit menu, click Delete.
When you are prompted to confirm the deletion, click Yes.
In the right pane, click LowerFilters.
Exit Registry Editor.
Restart the computer.
    LENOVO 64734VM
    15 inch
