Missing restore points
VisaVis
Hi:
Due to a sudden loss of electricity during booting , all the restore points are gone as reported by Vista 64 that there were no restore points created. Is there a way to recover these restore points?
I exported a registry file a few days ago, so is it a good idea to import it back to the current registry and use registry repair to remove duplicates, etc??
Also, where are these restore points stored?
This is about all you can do now. Make a new restore point and then begin to save them as you did in the past. The old ones are gone.
What I do in lieu of restore points is make and image once a week on Macrium Reflect. It is much better than restore. It is an image of the entire hard drive. It save me more than once.
Macrium Reflect FREE Edition - Information and download
Unless you are having major problems, leave the registry alone.
You do not need the old restore points.
Damn, and I guess a UPS too!
System restore points are stored in the "System Volume Information" folder in the root of all protected drives. By default it is hidden and even an admin account does not have access. Unless you fully understand what you are doing and have a good reason this should not be changed. Improper modification can have serious consequences.
I would try doing a chkdsk, see if it corrects the problem.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz, 3401 Mhz, 4 Core(s)
    16GB
    NVIDIA GeForce GTX 750, Intel(R) HD Graphics 4600
    Samsung 27" C27F398 Curved Monitor
    1920 x 1080 (HDMI)
    Samsung SSD 840 EVO 250GB Seagate ST2000NM001 2TB Seagate ST31500341AS 1.5TB
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP xw4400 Workstation
    Intel Pentium D Dual 3.4Ghz
    HP 0A68h
    5GB
    Realtek HD Audio
    Acer KN242HYL 24" (KVMS)
    1920X1080
    Seagate ST3120026As 120GB SATA (boot) Toshiba DT01ACA200 2TB SATA
    Logitech via KVMS switch
    Dell USB via KVMS switch
    50 Down, 10 Up
    Apache Web Server since 2001
+1 NTFS is a journaling file system. So there's always a chance that partial file corruptions may be fixed by chkdsk. It's worth a try before making lots of changes.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
