monitor not working with vga
arsehley
ive just unplugged all my pc cos i was having new floors put down ,
and when ive just set it up again the moniters not working. The pc is booting up fine
but the screen says no signal then just goes black,
i had the same problem when a pc repair guy came round and used the pc moniter to
connect my laptop, and when he put the vga cable back in the pc tower it was doing the
same as now, but he just did summit and got it working
anyone got any ideas
whats going wrong?
    Acer Apire m3201
    AMD Phenom 9150e Quad core processer 1.8ghz
    4gig corsair 800 mhz
    ATI Radeon 4870 512mbs gdr5
    32"
    320gb
    ocz extreme 600 watt
    4.0mbs
I had a monitor that did that, turned out to be one of the pins in VGA connector was pushed back into the casing. I bodged it up by pulling the pin back with pliers, but changed the cable in the end. I have also seen a monitor with one of the pins bent around and against the metal case, that was also carefully straightened, and worked fine.
Of course your monitor problem may not be anything to do with the above :-(
Barry
Barry
the pins are all fine
    Acer Apire m3201
    32"
    320gb
    4.0mbs
I think you have to go into the monitors menu and set it up for digital input or analog input.
    Cyberpower
    AMD Phenom X4 9850
    MSI K9N SLI V2
    8 GIG DDR 800
    EVGA 9800 GT 512mb
    onboard
    SyncMaster 220wm
    Hitachi something or other 500 gigs
    650 watts
I agree with Barry in that your best option would be to replace the monitor cable, especially as you have had this problem with it before. Just because the pins on the connectors are OK it doesn't mean to say that the wiring in the cable itself is. One or more of the wires may have a break somewhere which can cause this problem, especially if the cable is tightly folded and bound for the sake of cable management.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
im not to familiar with the vga cables because its not my computer .i use hdmi for mine
and i was just wondering once the vga is connected both sides should it usually show
on the moniter just without audio :huh:?unlike HDMI
ill try again tomoz see if it works ,if not just buy one
but its only about year old the pc and the vga cable has only been unplugged twice:rolleyes:
    Acer Apire m3201
    32"
    320gb
    4.0mbs
Does this monitor support both HDMI and analog? If so, I believe you need to set that up in the monitor menu were you also set contract and brightness etc.
    Cyberpower
    AMD Phenom X4 9850
    MSI K9N SLI V2
    8 GIG DDR 800
    EVGA 9800 GT 512mb
    onboard
    SyncMaster 220wm
    650 watts
no vga and dvi
    Acer Apire m3201
    32"
    320gb
    4.0mbs
Just a thought...perhaps the bulb in the monitor has blown out!
    Cyberpower
    AMD Phenom X4 9850
    MSI K9N SLI V2
    8 GIG DDR 800
    EVGA 9800 GT 512mb
    onboard
    SyncMaster 220wm
    650 watts
re-read this please avg (its not meant to be taken offensively :) )
whats going wrong?
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
Not to overlook the obvious.... but do you have a video card? and if so are you plugged into it or are you plugged into the main board?
    Acer AM1201
    AMD 4800+ Dual Core
    3 GB DDR
    ATI Radeon 2100
fixed ..i just plugged it in the graphics card:o
rather than the motherboard lol
    Acer Apire m3201
    32"
    320gb
    4.0mbs
