Motherboard Help!
sooty1892
Ashley
Hi
I've got a quite old computer which is still using IDE connections. The CPU, graphics card and RAM are fine but the motherboard is really slowing it down.
Shops don't seem to be selling motherboards with IDE connections any more so is there a way of using a motherboard with SATA connections for IDE hard drives?
Thanks
    AMD Athlon 64 X2 Dual Core Processor 5400+ 2.81 GHz
    WinFast 6150M2MA
    3.00 GB
    ATI Radeon HD 5450
    built in with motherboard
    LG Flatron L197WH
    1440 x 900
    ExcelStor Technology IDE 149GB Seagate FreeAgent 298GB External
    Seasonic 330W
    Sagitta
    Logitech wireless
    Logitech wireless
    about 5mb/s (should be 20 :( )
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    40 Meg
Only a rare few are missing ide ports, though you will usually only get 1.
Second issue is its rarely the mobos fault, but your cpu and ram. And depend just how old your system is, you might not find a mobo to fit the cpu socket.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
Well the system im talking about is the one under 'my system specs'. Im only thinking its the motherboard because on boot-up it usually stays on a screen saying 'WinFast' for about a minute and the shutdown process takes a long time as well.
    WinFast 6150M2MA
    3.00 GB
    ATI Radeon HD 5450
    LG Flatron L197WH
    1440 x 900
    Seasonic 330W
    Sagitta
    Logitech wireless
    Logitech wireless
When did you last reinstall windows?
Also run a malwarebytes and a AV scan.
I think your windows is just slow.
I run malwarebytes and AV scans about every 2 weeks. Windows was last installed about 3 years ago.
Do you think it would be best to re-install to speed everything up again?
    WinFast 6150M2MA
    3.00 GB
    ATI Radeon HD 5450
    LG Flatron L197WH
    1440 x 900
    Seasonic 330W
    Sagitta
    Logitech wireless
    Logitech wireless
Its free, so why not.
Just save all your drivers and program files to an external and it should be a 2hr process.
