Solved mouse lag!!
ryin
I have a logitech mx610 laser mouse that I have used with my vaio laptop with windows XP and never had any problems. This summer I bought a HP 4830f desktop computer that has Intel quad core 2.4Ghz, 4Gb of ram, nvidia geforce 8500 GT video card with vista x64, and I usually always have some type of mouse lag, it is especially really bad when anything is downloading. does anybody have a solution for this issue, it is so annoying
Make sure your batteries are good and clean the laser lens also the latest drivers for your mouse.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
+1, bad batteries.:D
    E6850
    EVGA 122-CK-NF67-A1 680i
    4 x OCZ Platinum 1GB
    ATI Radeon HD 5850 1GB
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
Hi ryin, have you try a different mouse?
    E6850
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
Hi Ryin, and welcome to Vista Forums.
You might try to reset the wireless connection between the mouse and receiver to see if that may help. There usually a button to press on the receiver to reset/rescan for the mouse signal. After pressing it press the small connect button on the bottom of the mouse. Hopefully that will get a better connection without the lag.
You might also check around for any other radio frequency device that may be interfering with the signal causing a lag.
Ok I think I fixed it, I had the usb receiver in a ps2 adapter instead of the usb port, and i also adjusted turned off mouse shadow which i read has caused some problems.
That's great news Ryin. I'm happy to hear that it seems to be sorted. Thank you for posting back your results.
Never knew that could cause mouse lag.
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
