Problem Solved
But, why did you remove the post. The forums here help many people, and someone may experience the same problem that you had. If you had left the description of your problem, and posted your solution, then it would be there for other people to read when they have the same problem.
By removing your post, no-one will know what your problem was, or how it was solved, and therefore may be unable to solve the same problem in future.
