MSCOMCTL.OCX not correctly registered
I have Vista Home Premium.
When trying to install "Duplicate Cleaner" as Administrator, I get the message:
Code:
Run-time error '339':
Component MSCOMCTL.OCX not correctly registered.
Any advice?
Hello OldGrantonian,
Click on the "Start" menu (the Windows logo normally located on the
bottom left of your computer.
Go to "All programs/Accessories" then right-click on "Command Prompt" and
choose "Run as administrator" from the menu.
After acknowledging the User Account Control warning, type the following
command:
regsvr32 C:\windows\ system32\mscomctl.ocx
This is one of many fixes i have seen for this error, try it and post your results. Good luck.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
command:
I followed the instructions, running the command prompt as an administrator.
I got the message:
DllRegisterServer in c:\windows\system32\mscomctl.ocx succeeded
I tried again to install Duplicate Cleaner from its MSI file. I got the same error as in the OP :(
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
You could try re-installing the MSCOMCTL.OCX file, see if that helps, yours may be corrupt, if you do re-install, run the "Command Prompt" again.
Download MSCOMCTL.OCX file free : GiveMeFile.Net
Tried your suggestion. Same result :(
However, here's some more info.
I'm trying to run "Duplicate Cleaner", an excellent free program that searches for duplicate files.
With any program that moves or deletes files, I always "run as administrator".
However, I noticed that Duplicate Cleaner will start OK if I run as a normal user. (It probably won't delete certain files.)
Is that a clue?
When you start the Duplicate Cleaner, do you get the UAC prompt ?
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Scenario A ("run as administrator"):
- The UAC dialog appears. Click "Allow"
- The MSCOMCTL error appears
- The program will not start
Scenario B (normal user):
- No UAC dialog
- The program launches immediately
- During operation, some duplicate files will not be deleted
The only fix i can find for this is the one i posted, the only thing i can think of is that its a problem in the registry, have you cleaned the registry lately ?.
CCleaner - Download
(backup registry when prompted)
If this does not fix it, maybe there is something on the makers site that will help.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
