greeneggsandham
Power User
		I have a aus p5q-em with G45 intel chipset & i have had this board about a month almost now.
I'm using the onboard intel graphics with the VGA out to my VGA display.
This problem has only started happening within the last 20-ish days or so.
The display will periodicly flash black for a secound & then back on again? it's almost like changing your screen resolution but with no apparent resizing taking place, although it does seem to happen mostly when I expand windows more than any other time.
Everything still carrys on as normal on the computer when this display blackout happens.
I have tested my ram with memtest to rule out ram problems as it's new. I'm not getting any errors to suggest theres some ram issues or any related symptoms for ram associated problems. anyway & it's now past 3 memtest sessions with no errors.
I have also carried out orhtos & prime95 test just to stress the Ram & CPU to see if I got any errors reported with nothing reported. Only once did a blackout happen during testing when I was maximizing a window but the test reported nothing?
I can't find anything in windows event log either. Anybody have any similar problems or know what could be causing this dispaly issue? Is it a graphics problem.
Thanks for your time.
- Self Build
- Intel Pentium D 925
- Asus P5Q-EM
- Corsair PC2-8500
- Onboard Intel GMA X4500HD
- On board crap!
- DGM 15" inch generic?
- 1280x 1024
 - PSU
- 380W Antec Earth Watts
 - Case
- Antec NSK 2480
 - Cooling
- Scythe Mini ninja
- generic
- generic
- Depends what time of the month it is? I have a uk isp.
		 if you don't have them.
